Supercharger flutter/chirping
Old Oct 18, 2025 | 05:06 AM
  #41
DOXI's Avatar
Originally Posted by SuprchdAP2
Hey, sorry I have been out of town and could just now reply. If I had not used the supersize Forge valve, I would have used this one from Turbosmart with the soft blue spring - https://www.turbosmart.com/product/k...cZ-dEUd1MC7P42. This is still significantly larger than the plastic Bosch valve that comes with the SC setup. I personally think the Forge may have been overkill, and as I said below the sound of the venting air is loud with my uninsulated vented carbon fiber hood. If I had the time and the inclination, I would try different valves and see which produces the best result. But for sure the larger, better quality valve will get rid of the flutter. What I don't know is if a slightly smaller valve would make a little less noise.
Thanks! I'm thinking smaller ports/valve = more pressure = more noise. So bigger probably quieter. I managed to find a Forge Supersize left on eBay, and I got a green spring (5 - 15 PSI). Now I need to find someone to weld bigger ports on the pipes to install it. If anyone know anybody in the Miami/South Florida area I'd appreciate the contact.
Old Oct 18, 2025 | 05:18 AM
  #42
SuprchdAP2's Avatar
Good deal, and I can't argue with your logic because I made the same decision. I know of a good shop down in Boca if you don't mind a little drive. It's called HD Werks. Ask for Pete - https://hdwerks.net/.
steven975
Jun 24, 2012 09:47 AM
Competitor9
Jul 8, 2008 05:42 PM
ego
Oct 29, 2007 07:16 AM
SIIK2NR
Oct 11, 2005 07:45 AM
DJHohum
Feb 21, 2001 06:15 PM
