The Ultimate GReddy Turbo Kit Thread
Old Jun 11, 2011 | 08:48 AM
  #1141
S2KCHRIS305's Avatar
heres me setup im going for :
berk HFC
pfab manifold
aem ems
aem wideband
aem boost gauge
Greddy blow of valve ( im not sure which one )
and the rest of the parts such as piping and down pipe will be all original from the greddy kit .
and running at 8psi .what you guys think ? how much power u think il have ? and do u think its a reliable setup ? also is boost gauge needed?
Old Jun 12, 2011 | 11:46 AM
  #1142
bump!
Old Jun 12, 2011 | 12:07 PM
  #1143
guamie's Avatar
I dynoed at 271hp @7psi the same setup minus the Pfab manifold.. Hopefully you'll get more. Im getting the Pfab manifold and a retune soon. I'll post up numbers when I get retuned. I've had the setup this setup for almost 30,000 miles and it's been reliable so far. I guess it depends on the tune?
Old Jun 12, 2011 | 01:11 PM
  #1144
Revenge's Avatar
Originally Posted by S2k.berto
Originally Posted by S2KCHRIS305' timestamp='1307080477' post='20644769
is the manifold cracking a very common issue on the greddy kit ? what other manifold will fit ? i wanna be reliable n what causes it to crack
yup it is.. and im not to sure but i dont think theres a replacement.
I think pfab makes one
Old Jun 12, 2011 | 04:16 PM
  #1145
Yea pfab makes the mani . N il be happy with 280hp . N most likely CFT will be tuningmy car .
Old Jun 15, 2011 | 01:21 AM
  #1146
Nyther's Avatar
I finally got the car done!
Specs:
-Greddy Turbo kit
-Fidanza flywheel
-ACT pressure plate & OEM disc
-Berk 3" headerback with HFC
-PORTED WASTEGATE
-BRK8EIX spark plugs
-Castrol Magnatec 5W-40 Full synthetic engine oil
-AEM UEGO gauge
-Autometer 3376 full sweep electric boost gauge
-"European" Octane 98 gas
The Emanage Ultimate was previously tuned by a former owner..
I did some carefull testing on the streets and i got the folowing results from the Boost & wideband gauge:
BOOST: 10-11PSI
-Idling AF 15
-Cruising AF 14/15/16
-Slowly getting on the gas and into boost ( 5 PSI ) AF 12/13
-Full boost 3500-5000RPM AF 11-12.5
-Full boost highway 5000-6000RPM AF 10-10.5
The thing is, the AEM uego CANNOT read lower than AF 10! so i might be hitting AF 9.5 or something... way to RICH!
But it looks like that i can drive around pretty safely on this "old" tune.. I do have an appointment to get a NEW tune..
What do you guys think?
Old Jun 15, 2011 | 02:21 AM
  #1147
chViETnk's Avatar
^ i would not boost until the retune if i were you, if your running too lean.
also if our planning to boost over 10psi, your gonna need a new map sensor.
i was looking at the berk 3" as well, im interested in seeing how you do on the tune with creep/spiking issues.
Old Jun 15, 2011 | 02:31 AM
  #1148
Nyther's Avatar
I made a mistake, its running to RICH!
I have not gone over 7500 rpm's and i've not seen the boost going over 11PSI..
I set the autometer boos gauge warning at 11.5 and memory shows it has not passed that mark..
i DO however have ported the wastegate!
Old Jun 16, 2011 | 04:06 PM
  #1149
Nyther's Avatar
What oil cooler do you guys reccommend?
What about a 13 row, 13"long oil cooler.. or do i need to get a bigger one?
Old Jun 22, 2011 | 08:14 PM
  #1150
s2kS0L's Avatar
Has anyone heat wrapped their IC piping? I bought extra adhesive backed wrapping for the a/c lines and wanted to gauge the crowd. Thanks.
