The Ultimate GReddy Turbo Kit Thread
Old Jan 19, 2009 | 05:29 PM
  #211
sabelotodo's Avatar
oh 12-14 psi goal for me would be 350whp no more then that
Old Jan 19, 2009 | 06:14 PM
  #212
Chris_Lum's Avatar
Originally Posted by asukadc' date='Jan 19 2009, 02:01 PM
anyway, where do you get the S/S lines for the hoses... like this pic.. and how do u secure the fitting, looks like a twist type?
The fittings are Earl's Econ-O-Fit hose clamp fittings. They're somewhat of a "dress up" item for the hose ends, but on SS lines like the ones i have in the picture, it also helps to keep the frayed SS braids from poking fingers. The fitting just slides on to the ends of the hoses and has a hose clamp built in so you can tighten the hose end. Gives a clean look to all the hoses...Earl's has a variety of sizes.
Old Jan 19, 2009 | 06:16 PM
  #213
CalBear07's Avatar
JoeyBalls is at 12 PSI, I believe, but he uses meth.
Old Jan 19, 2009 | 06:19 PM
  #214
JoeyBalls's Avatar
Yeah, I am 12PSI and Water/Meth, For some reason my PSI falls to around 10PSI at redline, even though I am set for 12PSI, Turbo seems to run out of steam, but With the Berk HFC and 12PSI, I am making 253ft/lbs of TRQ at like 3,800RPMS and HP at REDLINE is 317 on a DYNO-DYNAMICS......
Old Jan 19, 2009 | 07:38 PM
  #215
s2kadl's Avatar
Im at 15psi on E85. Turbo still has some left in it but wouldnt dare go any higher. Ill have to go down to a dynodynamics and get a power run done but it 95 degree F down here at the moment!
Old Jan 20, 2009 | 06:45 AM
  #216
asukadc's Avatar
cool, wat about the ss line
Old Jan 20, 2009 | 06:54 AM
  #217
RichV's Avatar
Are you running any catch cans Joey. I have read a lot about them, but have no idea how to install them or exactly what they do.
Anyone shed some light on this for me?
I creep to about 11-11.5 PSI in this 30 degree weather, but I don't really want to.
Old Jan 20, 2009 | 11:49 AM
  #218
Chris_Lum's Avatar
i'm sure you can find them at performance hose companies...i got it from work when i was at greddy, not sure where they were originally purchased from.
[quote name='RichV' date='Jan 20 2009, 08:54 AM']Are you running any catch cans Joey.
Old Jan 20, 2009 | 11:59 AM
  #219
JoeyBalls's Avatar
I dont have a cath can but I can just replace the Clear tube that goes from Valve cover to intake, its very cheap, creeping to 12PSI could be very bad depending on what your AFR's and timing are tuned too
Old Jan 20, 2009 | 01:12 PM
  #220
asukadc's Avatar
you should... look top of this page, i have mysetup.
