The Ultimate GReddy Turbo Kit Thread
Originally Posted by TRBOKEV' date='Jan 21 2009, 12:11 PM
I kept the air pump (Just to clarify). It helps on warm up of the car.
it's for emission, have u seen the wideband, u get like 17afr/18 when pump is on cuz cold start burns rich.
Originally Posted by asukadc' date='Jan 21 2009, 02:27 PM
i don't think that's why it's there.
Hey guys just got my greddy kit installed om my02, too much fun for words,
one small problem, is every now and then the ecu throws the code p0171 and p0170, not sure why the aem gauge says everything is good on the fuel side maybe im not looking in the right spot.
this is sorta hard cuz there is alot of reasons for this
Originally Posted by Revenge' date='Jan 21 2009, 04:19 PM
soooooo do I put a filter on it or just block it off???? Also what size is the air intake 60-70mm?
which hose are you referring to? If the following hoses are disconnected:
Breather hose: intake side you can cap off, valve cover side needs a filter
Air pump hose: intake side you can cap off, air pump side = filter maybe? Do not cap this side off.
Originally Posted by Chris_Lum' date='Jan 21 2009, 05:19 PM
suction pipe = 60mm
Originally Posted by Revenge' date='Jan 21 2009, 03:58 PM
Seems like a bunch on stuff on the forum about this code, seems like you may have a leak in one of your vacuem line connection. Just make sure they are all secure. Just check out the forum.
