What is the largest bottom mount turbo?
Originally Posted by gnehc1,Apr 6 2010, 05:19 PM
Would rotating the compressor housing to point downward help? It appears that the precision turbos point up by default. Is that even an option?
Read over my thread you will see the fitment of the 6265E cover and my 5965B cover.
Originally Posted by dsddcd,Apr 6 2010, 02:40 PM
I dont think that will help and you will have to make your own discharge piping.
The revhard manifold sits closer to the engine so you have more room for larger turbos. like I said eariler I ran an sc6152 with .6 ar hotside and .8 ar cold. with no problems, or frame notching. But I was using a bottom routed intercooler pipe.
My notch is much bigger than that. Mine goes all the way to the top, I had them make it bigger cause it was vibrating, I also had my motor mount changed. Maybe I should put some heat sheild on it.
hammerhead300
Jan 31, 2019 05:45 AM
S2KEvolution
Forced Induction For Sale
Apr 9, 2011 11:34 PM
