When removing the air pump
Old Feb 18, 2006 | 03:51 PM
WalkingDrunken's Avatar
Default When removing the air pump
When removing the air pump, not the engine , does the valve on the intake manifold need to be blocked off or can you just leave the valve in place and it'll stay shut?
I always see people saying that they blocked it off but is that just so you can remove the valve and get a different look, and also lose that .1 pound.
Old Feb 18, 2006 | 04:11 PM
Sideways's Avatar
That is correct. Just don't hook the vacuum to it and it won't function.
Old Feb 18, 2006 | 04:49 PM
Perfect that's what I thought. Thanks
Old Feb 20, 2006 | 05:41 AM
Fyrestrike's Avatar
I disagree, you can feel exhaust gasses escaping through that valve with the engine on even with the vacuum line disconnected.
Old Feb 20, 2006 | 06:56 AM
So you think the block off valve is required. I'll have to go check my in a minute to see if I feel them also.
Old Feb 20, 2006 | 07:08 AM
XclusiveAutosports's Avatar
Damn, I just took out my air pump last night. I was hoping that I could just disconnect the pump without using a block-off plate .
Old Feb 20, 2006 | 08:48 AM
I just went out and checked. I could not find any deffinitive evidence that any air comes out. I could not feel any air coming out of the valve at all even when reving it up a little. Is there someone with a a more clear cut answer to if air does come out of the valve.
Old Feb 20, 2006 | 09:20 AM
I just took a look at the air pump and now I think that if you leave the solenoid on the car then you don't need a block off plate because it will stay shut since it has no function with the EMS. Is this correct?
Old Feb 23, 2006 | 04:20 PM
SoCalIsMyLife's Avatar
Has anyone found a solution to fixing the CEL caused by taking the pump out? I read a thread a while back when some guys were trying to do it.
james0933
Aug 26, 2019 08:48 AM
whatis
Aug 9, 2011 12:37 PM
jimtway1
Jul 1, 2010 10:00 AM
WalkingDrunken
Apr 16, 2006 07:51 AM
2Ting
Oct 30, 2002 08:18 PM
