Prepping for BSP
Old Dec 4, 2012 | 06:55 PM
  #311
sirbunz's Avatar
Originally Posted by Z3papa
I may be joining the BSP game as well since I gain a fair amount with header/exhaust mods. Probably running on 17" wheels with probably 275/35-17' front/295/35-17 rear. I will also be looking at the RS-1's but it may be tough up front.
I'm pretty exited about this build. I hope it goes well for you. Take many photos and keep records! Even though this is an s2k forum, I would like to hear of the other builds.
-Marc
Old Dec 6, 2012 | 05:16 PM
  #312
03threefiftyz's Avatar
Do any of you guys have pics of the 18x11/11.5 on the car yet?
Old Dec 7, 2012 | 05:00 AM
  #313
sirbunz's Avatar
Jason's car is the only one I know that has been photographed with the 18x11s. His set has 8.5" backspacing...
-Marc
Old Dec 7, 2012 | 08:38 AM
  #314
josh7owens's Avatar
Why hasn't he removed his soft top yet?
Old Dec 7, 2012 | 08:49 AM
  #315
That pic is probably 4+ years old, the soft top is removed.
Old Dec 8, 2012 | 02:14 AM
  #316
legend4life's Avatar
Originally Posted by rrthorne8
Originally Posted by legend4life' timestamp='1354586934' post='22187929
[quote name='03threefiftyz' timestamp='1352927808' post='22151445']
The biggest problem for the s2k's in SP is the same as STR, diffs. Pretty sure Jason had at least one spare with him at Nats.
I'm out of date, are you referring to the issues with the OSG diff's? If so, did their revised version not end up fixing it?
i believe the strength of the oem ap1 in particular casing is in question. Bearing caps and low strength eventually will end your ring and pinions life... The OSG issue was resolved
[/quote]
Thanks for the reply, I haven't heard of oem diff failures in STR, are AP1's breaking diff's?
Originally Posted by sirbunz
As for the diff, simply don't launch unless you have to. The AP2 housing is much stronger and a properly built diff will last longer. Even the strong diffs built for drag racing are rebuilt frequently.
Is a launch on just an AP1 STR car that hard on the diff? What constitutes a properly built diff, or how can it legally be made stronger?
Old Dec 8, 2012 | 04:23 AM
  #317
steguis's Avatar
With the rain we're having here in NY, just reminded me to factor in a wet weather setup. I'm thinking narrower wheels for the wets and maybe save money buy running 275/40/17 Hoosier H2O on my 17x9 6ULR (STR) wheels?
Old Dec 8, 2012 | 04:45 AM
  #318
I'd rather have a 245 wet on a 9" wheel...
Old Dec 8, 2012 | 05:29 AM
  #319
steguis's Avatar
Even better. That'd cost less
Old Dec 9, 2012 | 07:46 AM
  #320
steguis's Avatar
Sourced and ap2 engine and trans. Hopefully I'm finally going to get some traction on my build.
