Prepping for BSP
Old May 16, 2013 | 07:14 AM
  #951
IntegraR0064's Avatar
Originally Posted by rrthorne8
new diff adjustment to help with lock timing, need to go slightly more aggressive with removing delay spring but its close now.
need to add a few percent of overall lock back also. Fresh 10.9 flared bearing cap bolts cleaned and torqued thanks to 3rAuto's engine / tranny rebuild room
Nice post! So you're going with faster lock timing on your diff? What made you decide that? Still trying to wrap my head around diff tuning.
Old May 18, 2013 | 10:26 AM
  #952
rrthorne8's Avatar
I need the diff to start locking sooner to keep the inside wheel from spinning up when trying to add power. Once it starts to lock I wouldn't mind it coming on nice and progressively, but having this torque delay before anything happens is no good. I may end up going with lower ramp angles to slow the lock and run little to no delay springs to get it started as soon as I add any power
Old May 18, 2013 | 07:36 PM
  #953
sirbunz's Avatar
Getting close... Alignment on Tuesday, Tune on Thursday, check into hotel in Lincoln Thursday night! Pressure is on!
-Marc
Old May 18, 2013 | 08:17 PM
  #954
steguis's Avatar
Gah, the fixing never ends. Had a coolant leak due to a crack in the drain plug (Koyo radiator), we fixed that with a new plug. Car was randomly running poorly...due to a loose injector clip, that's fixed too with new clips. Today went for an alignment and found my alignment is all over the place and I can't get it to what I want because my driver side compliance bushing is torn and it seems that all my bushings are out of shape. I guess the age of my car (11 years) is catching up to me. Now I have to decide to either just replace all my control arms (most expensive, easiest to install, and I can keep my old set as spares) or replace all the bushings. Rear ball joint seems to be a bit wonky as well so might as well replace that. Good thing it seems a 97 accord front ball joint works in the rear of our car so I don't need to buy new hubs.
Old May 18, 2013 | 08:19 PM
  #955
steguis's Avatar
Oh and installed the Shorai 4 lb battery today (finally) which is pretty sweet but forgot it was brand new and left the car on while it was getting aligned and completely drained it. Had to get jump started. Have to remember to put the car on a tender for the next few days so it fully charges.
Old May 18, 2013 | 08:49 PM
  #956
rrthorne8's Avatar
had the shorai 1.8 lb. did that once, it was ok, second time, it was toast. back to the 10lb deka for a while.
Looking good, cant wait to see it! keep going, so close mate!
Old May 21, 2013 | 03:42 AM
  #957
Z3papa's Avatar
-Marc
Don't work yourself up too much. I raw timed your competition at an event last year. You're probably going to have to use Andy Hohl/Joe Tharpe in SSP as a benchmark to work off unless he has really figured out how to get his car moving a whole lot faster. Just sayin. Sorry I won't be there
Old May 21, 2013 | 09:06 AM
  #958
sirbunz's Avatar
Originally Posted by Z3papa
-Marc
Thanks! Unfortunately for me, Robert will be there! I will use him as a banchmark and hopefully get a feel for the car. This will be the first event I have ever driven it assuming the alignment and tune go well. If not, Dave and I will bring his car for STR.
-Marc
Old May 21, 2013 | 09:54 AM
  #959
Z3papa's Avatar
Originally Posted by Z3papa' timestamp='1369136537' post='22556649
[quote name='sirbunz' timestamp='1368934578' post='22552228']
-Marc
-Marc
[/quote]
Woops -- referencing the wrong weekend. Thought you meant Peru. Robert's a whole different kettle of fish altogether. Would be worth the price of admission though.
Old May 21, 2013 | 07:34 PM
  #960
steguis's Avatar
Haha, yet another one of my letters rejected by the SEB. I think i'm 0 for 4 right now. They won't let me cut a 2" hole in my bumper to terminate my brake ducts properly. Instead I'll just have to route it all the way to the bumper opening. No biggy, just looks like ass.
