S2000 STR prep resource
Nick, he asked suggestions on fixing a mid corner push and if fixing that mid corner push is by running less rear camber then you are removing or moving traction yes. I see your point. He might be better off removing some camber to balance the mid corner push and gain some corner exit drive traction.
Makes sense
Makes sense
Dang! Thanks for mentioning the bigger rear stock bar of the AP1. I've been thinking of adding more bar since I'm probably going to be forced into more front bar for a while.
For a car that has a 50/50 weight balance, the most possible grip that can be attained will be achieved when the roll resistance and subsequent loading of the tires is equalized front to rear.
