S2000 STR prep resource
Originally Posted by glagola1,May 3 2010, 06:12 AM
FWIW I had understeer mid corner with no rear bar. I couldn't make the car work with no rear bar but a lot of people seem to think it's better.
My car feels very balanced to me but might be oversteery for some.
Comparing to times, the car is definitely faster than before.
Here is a sort of explanation of my opinion of balance using my own arbitrary scale to illustrate the effect of removing my rear bar.
5 is perfectly neutral, 10 is very oversteery 0 is very understeery
Turn in
Before 8
after 5ish
Transitions
Before 9
After 5ish
Corner exit
Before 6
after 4 (but I am on the gas much sooner and thus going faster)
Mid corner
Before 8
After 4
So even mid corner is better than before but I overshot by a little and want to figure out a way to get a little more mid corner rotation
More front camber. I'd get some camber adjustment and get at least 2.4 out of the front.
Originally Posted by robinson,May 2 2010, 01:17 PM
Two things:
You are carrying a lot of slip angle. Do you like it that way, or are you just trying to deal with it?
Don't forget to wear your chin strap :-)
The green strap is for the Defnder head and neck restraint quick disconnect.
Originally Posted by alvanderp,May 3 2010, 07:15 AM
That said - you usually fix mid-phase issues with spring. You can either reconnect the bar or add some rear spring. You might also try removing some rear camber if you don't feel like messing with spring.
Try these. Maybe you have already
Try a click or two less front rebound maybe more depending on your shocks.
Make sure you have enough bump travel and that you're not riding on or hitting the bump stop mid-corner.
You can also try adding a 2 or 3 mm spacer in front and space out the wheels if you have any room. Not sure if that's STR legal though but I don't see why it wouldn't be.
Make sure your front tire pressure is ideal. Try dropping it a bit just to see if it might help.
Hope one of these helps.
