S2000 STR prep resource
Old Jun 24, 2011 | 04:11 AM
  #4081
daverx7's Avatar
Originally Posted by glagola1
Hey guys, the club is for us, by us. If you want to be able to fully tune your none 06+ S2000 you should just write a letter (email) asking for a proposal like James's or less specific. If enough people have the "me" attitude about a particular subject, it becomes less "me" and more "we"
Seems to me that the current proposal doesn't go far enough for parity for all S2000s despite the fact that they are so similar otherwise.
www.sebscca.com
Well said, Matt.
I'm still in the camp of all or none, but will take any step in the right direction. Yes, I can be a bit selfish.
-Dave
Old Jun 24, 2011 | 09:09 AM
  #4082
///MIKE's Avatar
www.sebscca.com
YEAH! Let's all send in letters that allow us to gut our soft tops next... That will make the CR pointless!
Just kidding guys....
I'm all about MEEEE Racing.
Old Jun 24, 2011 | 12:54 PM
  #4083
//steve\\'s Avatar
Anyone need some 800lb springs? I've got a full set of hyperco's that came on my clubsports that I won't be using. I'm more than willing to split the set and also willing to let them go for a more than fair price as I have no use for them.
I'm also willing to trade for 700lb hyperco or swift springs as long as they are 2.5" ID and 5.5"-6" tall.
I figure some of you hardcore autocross guys might be able to make better use of the springs.
Old Jun 24, 2011 | 01:59 PM
  #4084
imstimpy's Avatar
www.sebscca.com
I submitted three different responses due to the content in the latest Fastrack.
Old Jun 24, 2011 | 08:26 PM
  #4085
sirbunz's Avatar
Originally Posted by 762
Marc, from what I remember the flashed CR you drove at the event was running 0 toe in the rear. This would make it very difficult to put the power down. However, in the tuned cars i have ridden in, rear grip was no more of an issue then in any other ap2.
I have been playing around with Jason Rhoades comparative vehicle dynamics thrust calculations and it has really gone to show me how big the tune is for the car.
I agree ... I found out Jon's CR (the flashed CR your referring to) had about an inch of toe out when he put it on the alignment after Blytheville. The car was extremely loos everywhere and I suspected something was wrong. Jon had it looked at as soon as he got back. I have driven this same car before at one of their local events and it was more stable. I have driven many other STR prepped S2000s along with my own B-Stock prepped S2000 with the flash. IMO, power isn't what makes the S2000 fast. The car's ability to dance is it's greatest strength. Trying to set this car up to acceleration from one point to the next will slow it down. Adjusting the car for smooth mid range power would be my goal. Everyone has their own preference, this is just my .02
-Marc
Old Jun 24, 2011 | 10:05 PM
  #4086
PilotSH's Avatar
Originally Posted by PedalFaster
Originally Posted by PilotSH' timestamp='1308866969' post='20713661
No,it's really annoying when people don't think before they post.
It's a lot harder than it used to be, but you can fix this by doing the following:
  • Click on your name in the top right corner of the screen
  • Click "My Settings"
  • Click "Profile"
  • Click "Manage Ignored Users"
  • Type "josh7owens" into the text box and make sure "Ignore Posts" is checked
  • Click "Save Changes"
Voila, problem solved.
Hahaha, thanks for the tip Steve. Now that Josh is more informed, I'll give him a shot before I "ignore" him. I know he means well. And I don't think I'm that much of a d!ck, at least I hope no one thinks I am.
Old Jun 25, 2011 | 04:32 AM
  #4087
PilotSH's Avatar
Originally Posted by jrose29
So its about time to purchase another set of tires. We have some Toyo's for rain and 255 kooks with about 120 runs.
Couple questions:
When do the kooks heat cycle out? Or will they grip till cords?
Has anyone tried the 245/40 kook? I am leaning towards this for the stretched sidewall and slight gearing improvement. Whats everyones thoughts?
I'd stick to the 255s. The 245s transition better, but don't have quite the ultimate grip in sweepers. Also, the 245s are similar in height/gearing, so no real gearing advantage.
Old Jun 25, 2011 | 07:04 PM
  #4088
josh7owens's Avatar
Is it a bad thing to pick up the front inside wheel while turning?
I wouldn't think it ideal, but how do you keep it on the ground?
Old Jun 25, 2011 | 07:53 PM
  #4089
robinson's Avatar
Well, any wheel not on the ground is not helping your traction circle, so I say, not great, but it is a side effect of your setup.
If you have a stiff front and soft rear, this is common. One way to keep this from happening is to use stiffer front springs relative to your front swaybar and/or use the rear sway bar. It's not as simple as this, but generally this should get you in the right direction.
Old Jun 25, 2011 | 10:41 PM
  #4090
Orthonormal's Avatar
It doesn't even look like it's off the ground in that photo.
