changed my diff/trans oil today....
Old Jan 31, 2006 | 05:00 PM
riceburners2001's Avatar
Default changed my diff/trans oil today....
i changed the trans and diff oil today, and i dont have a torque wrench.....so i just tightened the bolts pretty tight.....that should be ok right??
Old Jan 31, 2006 | 05:02 PM
04RioS2k's Avatar
yes should be fine, just don't tightened it too hard where it'll strip the bolt...I should know from experience.....
Old Jan 31, 2006 | 05:05 PM
pdexta's Avatar
You should be fine. Just watch for leaks.
Old Jan 31, 2006 | 07:21 PM
XclusiveAutosports's Avatar
I just changed my diff/trans fluid the other day also and I was dissappointed because I just bought a $70 torque wrench and I couldn't use it because of where the fill bolt was on the diff. I ended up just tightening it by feel, as long as you don't go crazy tight you should be fine.
Old Jan 31, 2006 | 07:32 PM
ill just check for leaks in few days....
by the way, for those of u that dont kno, make sure u get a good pump.....i bought a cheap ass one to save $ (still like $5 for a stupid pump.. ) and took like 5 min to pump 1 qt!! and the hose kept falling off and shittt now i have oil all over the floor of the garage....
Old Jan 31, 2006 | 07:38 PM
^ YES!, a good pump is absolutely key for changing the diff/trans fluid. I went to pepboys the other night for a fluid pump and the retard behind the counter tells me that they only had a handpump POS that cost me 5 bucks. I wanted to change the fluid that night so I just bought it and went home to change the fluids. To make a long story short, TWO HOURS later the fluid was still siphoning, it was the biggest POS I have ever seen. I went back to pepboys two days later and I see in the next isle over they had a good pump 20 ft. away, and I was able to change both fluids with it in under an hour. Definitely get a good pump! One like this works great: http://cgi.ebay.com/TRANSFER-WATER-GAS-OIL...1QQcmdZViewItem
Old Jan 31, 2006 | 08:37 PM
[QUOTE=XclusiveAutosports,Jan 31 2006, 08:38 PM]I went to pepboys the other night for a fluid pump and the retard behind the counter tells me that they only had a handpump POS that cost me 5 bucks.
Old Jan 31, 2006 | 09:42 PM
ihyperxboy's Avatar
If you don't mind me asking, which differential and tranny fluid did you end up using? It's also time for fluids change in my car. I went to Honda and bought their stuff, but just wanted to see what you guys used. Are there other products out there that i should consider?
Old Jan 31, 2006 | 09:50 PM
ihyperxboy's Avatar
nevermind, i failed to read further down the forum topics where a member posted the question up for everybody.
s2konroids
Sep 6, 2012 01:40 PM
Danfotoman
May 28, 2012 05:25 AM
AlyWW
Apr 20, 2009 07:55 AM
Kaiser
May 6, 2005 11:43 AM
esracer
Mar 2, 2005 10:41 AM
