ECU Reset gave me .4 second increase in performance and fixed AC
Put the fuse back the right way, not upside down otherwise it will not work.
Yes it shouldn't matter which side the fuse goes in, and I may have jumped the gun and put that in there. The reason being is that, when the fuse was put back upside down, the reset of the ECU didn't work! But I am sure it is just an isolated incident.
But this also tells you that unless you have the idiot lights on to clear you may not know if the ECU reset is indeed done.
First thing you will notice when the ECU is first reset, you will observe bit of rough idling and when the rev start to come down it may come down to the stall point. If everything seems normal, your attempt of resetting may have failed.
I have reset my ECU by removing the positive side connection from the battery (didn't know which fuse to pull and was too lazy to find out - although it would have saved the trouble of resetting the radio and all my channels
Anyway, I never had the check engine light come on; does this mean it didn't reset?
).Anyway, I never had the check engine light come on; does this mean it didn't reset?
I think it's because when you put anything that alters
the air/fuel mixture ( intake, etc...) the ecu readjusts
itself back to its factory spec. resetting the ecu comes
in handy this way
I Think!
in handy this way
I Think!
-- Aaron
amartin
Aug 27, 2001 10:12 AM
