Please someone help!
Old Dec 14, 2004 | 12:06 PM
WhiteS2k's Avatar
Originally Posted by Ludedude,Dec 14 2004, 12:24 PM
I shook the spare, it didn't budge...
Where did you guys learn to read?
Originally Posted by MulderATO,Dec 14 2004, 01:06 PM
This may sound like I am a tard but I tried to get the cover off last night to make sure it wasn't the spare and I couldn't get the thing off. How do I remove the carpeting covering the spare without destroying those little plastic fasteners?
I wonder how he "shook the spare" without getting the cover off. Back to reading class.
Old Dec 14, 2004 | 12:33 PM
MULDER's Avatar
[QUOTE=WhiteS2k,Dec 14 2004, 01:06 PM]
Old Dec 14, 2004 | 12:40 PM
MULDER's Avatar
Originally Posted by piecesofcurb,Dec 14 2004, 05:39 AM
Sounds like an annoying buzz I had coming from the same area. I wasn't able to find the cause of the noise until I was installing my new soft top and had removed the plastic tray pieces where the top folds. I found that if I reached up under the back of the passenger roll hoop and tapped the top motor, it made the noise that had annoyed me for so long. I made a wedge out of electrical tape and stuck it between the motor and the body of the car. I then put 3M automotive tape across the bottom of the wedge to hold it in place. The pressure of the wedge on the motor has stopped the buzz completely.
Hope this helps.
What would be the easiest way to check this? It sounds like a pinball machine . It was worse today than I have ever heard it. I believe it is due to the change in temp around here.
Old Dec 14, 2004 | 03:11 PM
MULDER's Avatar
allkingz ,revhi ,WhiteS2k ,JasonX82
You guys were right. I went back, BENT BACK THE CARPET, and shook like hell........the I heard it. Tightened it up, went for a drive and it is gone.
Thanks alot guys.
Old Dec 14, 2004 | 03:15 PM
revhi's Avatar
Why are you having trouble getting to your spare? There should be 3 clip things on the top of the carpet piece that covers yuor spare. They have little handles on them so you can grab and pull. Once the 3 clips are removed the carpet piece should come right off. No need to bend anything.
oOweEe's Avatar
Im gettin this little tapping sound comin from the passenger side too. It seems like its coming from the conv top. Sounds like a little pebble or sumthin stuck in the bars or something... Is that wat you guys are hearing??
Old Dec 14, 2004 | 04:54 PM
WhiteS2k's Avatar
To see if what you are hearing is what we are talking about, try this experiment:
Go to your car, and loosen the nut that holds the spare tire down (the instructions on how to get to the spare tire are above), then drive around some bumpy roads. You'd hear the sound we were talking about. If that is the same sound you heard, then it is the same thing. If the sound is different, then you have a different problem. Good luck.
Comanche5
Nov 21, 2009 07:03 PM
foz
Nov 20, 2008 05:07 AM
NFRs2000NYC
Oct 14, 2006 12:26 PM
GHS2K
Feb 7, 2003 04:06 PM
noscargo
Oct 1, 2002 11:15 PM
