Supercharged guys
A properly tuned AEM EMS is definately a good way to go. The VAFC won't change the timing that helps so much with FI. It also doesn't allow you to change injectors, loose the cat or whatever tickles your fancy.
Poor is relative
I just wanted to run the SC safely and wasn't too keen on extracting max power. So an affordable, used, vafc v.1 fit my need. You can see my before/after vafc here: http://forums.s2ki.com/forums/showthread.p...threadid=191197.
If you want max power, search the forums for Sideway's threads.
I just wanted to run the SC safely and wasn't too keen on extracting max power. So an affordable, used, vafc v.1 fit my need. You can see my before/after vafc here: http://forums.s2ki.com/forums/showthread.p...threadid=191197.If you want max power, search the forums for Sideway's threads.
in a few weeks I will put a 8 psi pulley and Emanage. I ma runnig 550 cc injectors, the limit for the emanage according to the manual, but fperra is running 600 cc with his UR turbo and did not have any problem
jchan727
Nov 22, 2013 07:22 AM
lend_type_R
Mar 7, 2007 06:04 AM
