Test pipe install writeup?
Old Jun 10, 2006 | 02:25 AM
  #31
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Old Jun 10, 2006 | 06:23 AM
  #32
xviper's Avatar
[QUOTE=thetz99,Jun 9 2006, 10:53 PM] FYI
Old Jun 10, 2006 | 11:16 AM
  #33
SilverKnight's Avatar
whew just got done no CEL how heav is the stock cat whoa...........................!! I was suprised at weight diff.........
Everything came off easy since already had exhaust and header installs a few months back. The defouler o2 sims wor perfect, used 2 of them and no CEL.
To not twist the wire is very simple. Just slide cat around in a circle, dont even move the 02. Same with test pipe, just spiin 02 in a circle
Hardest part was getting the damn exhaust off the stock cat man.............isntall of new test pipe was cake compared ot taking off stock cat. Hoping I'm at high 290s close to 300 now
Old Jun 10, 2006 | 11:35 AM
  #34
Originally Posted by Emil St-Hilaire,Jun 10 2006, 03:25 AM
Old Jun 10, 2006 | 12:26 PM
  #35
slimjim8201's Avatar
I just washed my car for the first time since my test pipe went on. The rear bumper area surrounding the exhaust outlet had a nasty yellow film that was a BITCH to get off.
It's worth it for the sound though
Old Jun 10, 2006 | 02:17 PM
  #36
vtec9's Avatar
SilverKnight don't be hasty.. the CEL will not show up immediately. Wait until you've been through two tanks of gas before you celebrate
I've put about 4k miles on my berk withno CEL.. go O2 fix
Old Jul 17, 2006 | 07:59 AM
  #37
spectacle's Avatar
so just for clarification, I need two o2 sensor defoulers for the test pipe install?
Old Jul 17, 2006 | 08:06 AM
  #38
xviper's Avatar
This depends on which brand of testpipe you buy. Some come with a built-in extender, however, some of these "extensions" are not long enough or not at the correct angle and you may still have to improvise. On a test pipe that has no such extension, then yes, you use 2. The first one is drilled out to accommodate the sensor and the other one is left as is. Go read the link. Here it is again:
https://www.s2ki.com/forums/index.php?showtopic=229959
S2kNY
Dec 14, 2014 02:00 PM
mndthegap1
Nov 14, 2009 09:08 AM
stanz0r
Apr 3, 2009 03:37 AM
Syncmaster
Oct 8, 2006 08:05 PM
