Valentine One Users...
Originally posted by Yellow S2000
Here is some pictures of my V1 I installed.. Thanks to Reedz for the bracket mount idea.. I did not like the Concealed Display box so I modified it..
Other than cutting into the stereo cover (I will do that as soon as I have a second, pristine stereo cover that I'll keep around) did you have to do much to the display module itself?
Here are the pictures of my install.. The mount for the V1 can be found at:
http://www.s2000online.com/forums/showthre...&threadid=18740 You can thank James (Reedz) he goes into detail about the mount & parts needed.. the mount took 5 mins to construct & install.. Also there is additional threads you can go to..
The first thing is to take apart the Concealed Display box. All you need is the display plate(front display) & the curcuit board.. then I cut out the place for the display... (measured several times) I used my dremel tool for this project.
After I got the display in I had to figure out a way to get the phone cable with the jack on it so I cut a hole in the back big enough to fit it thru. I still had to pry up in the base to to fit the jack in..
I ran the remote display wire thru the shifter box & up to the 12v power area were I tap in to the 12v power for thr V1(sorry no pics)
This is what the back side looks like
here is the pictures of the V1 mount
I ran the cables for the V1 up the inside of the compartment
I did use a little Epoxy on the 4 coners of the remote display to help it stay in place. The circuit board has a couple of tabs on it that helps it stay in place. Also the Jack for the display does not hit any part of the radio on my system.. I don't know about your.
If you have any more questions please ask Hope this helps
