Why is it that there are so many...
If I wanted a car that was easy to drive I would have gotten something w/AWD (although that brings other fun/challenges). I know my driving ability can't push this car to its limits, that's why I am going to school to learn more. We bought the car knowing it doesn't have traction control to compensate for our inadequacies. Its a straight forward front-engine RWD roadster. Want to see some real lift-off ovesteer? Try an old 911.
Frankly, I think that makes it more fun. If I spin it and hit something (I have not), then it is my responsibility pure and simple.
There is no inherent design flaws in this car, we got exactly what we paid for (and more).
Originally posted by Mike Schuster
On oversteer, dang guys, with factory settings on factory tires my car had gross understeer in grippy conditions. Haven't you run at the limit on a cloverleaf and seen this understeer? Maybe my car is different than everyone else's. Anyway, I have been working hard to get rid of this understeer and now the balance of my car is nearly as good as the open wheel car that I race. And I know that the race car is set up well. Even with these improvements my Honda still has a slight understeering tendency at the limit in high speed corners on the track. Maybe some of you have never driven a truly balanced car in a high speed corner. If you are not feeling some rear slip angle you are not there yet.
That is how mine handles anyway. I would do nothing to change that.
Originally posted by sumir brahmbhatt
finally, i was beginning to think that we were going back to what got you banned in the first place
You know nothing of that situation or my subsequent reinstatement (with apology) or MY SUBSEQUENT REQUEST that my name be removed from this Forum.
I have not been here for many months, not because I was banned but because I did not want to be here. Only after recently noticing that some attitudes have changed (including mine
) have I decided to return.If you don't believe ME ask the forum membership director Honda Gal if what I say is true.
On bump-steer, I am going to have to do some more testing to see if I can identify the issue people are talking about here. One thing I will say though has to due with the rubber bushings. In a corner under lateral acceleration, the bushings will compress resulting potentially in change in camber and toe.
And Mike... you are probably feeling understeer because you are used to higher grip (formula car). This car can be shocked into understeer by overloading the front tire, and then unless you back off it will continue to understeer. Getting on the throttle too hard too soon can cause this. If you apply the throttle smoother and in a more linear fashion the car will oversteer controllably. Those were some excellent driving tips about spinning and sliding by the way!
The bump-steer also causes other problems... here is an example. When my friend (SCCA DSR CenDiv champion) drove Nick's car at Gingerman, one of his spins happened like this (I was riding with him both times): Coming out of turn-three the car was fully loaded up and drifting slightly. He had rolled the throttle back on and we were exiting the corner with very high rear slip-angles. When the car got to the exit curbing the suspension got unsettled and the car SNAP SPUN. There was no way to catch it. Keep in mind he drives a 140hp 900lb. sports-racer on slicks. He corrected to the right and the car's right rear tire stayed on the curb. The inside rear was also on a patch of bumpy pavement, and the car violently snap spun us in the opposite direction and through the dirt back onto the track. The other time he spun was in 8, heading toward 9... very high speed transitional sweeper section with very bumpy pavement. MANY S2000 drivers have complained it's tough to get the car through there properly, as the car is unpredictable in that section.
He was expecting to be able to drive the car on the limit without getting 'bitten' which happened to him twice. Many other street sports-cars, and most purpose-built race cars allow you to flirt with the limit much easier than the S2000. That's what my friend was expecting.
I understand what people are saying when using the statement 'I like the fact that my car is hard to drive at the limit.' But let's all be realistic... anything can be improved, and an S2000 without bump-steer would be a much more predictable and fun car.
Well I've watched Beig's posts with interest since his return. Frankly I don't think he deserves this.
I do think there's a fair bit of quiet 'Beig baiting' been going on. Old wounds being re-opened perhaps?
On the whole, I think this has been a good thread. It's a pity to see it starting to degenerate. Anyone get the feeling we've been here before?
It is only a car, who really cares what you do with yours!
I do think there's a fair bit of quiet 'Beig baiting' been going on. Old wounds being re-opened perhaps?On the whole, I think this has been a good thread. It's a pity to see it starting to degenerate. Anyone get the feeling we've been here before?
