03 ECU in an 00 AP1?
Old Mar 4, 2013 | 06:53 PM
  #21
schhim's Avatar
Ok, I got it guys. Here's the BLUF (bottom line up front): You get a new ECU, you're going to have to get your current key reprogrammed. Even if you have the key that came with the new ECU, the key will not fit the tumbler in your car. I just swapped mine tonight and I didn't get to drive it around much, just back to the house, to notice much of a difference.
Old Mar 4, 2013 | 06:54 PM
  #22
schhim's Avatar
PS, I had my car dyno'd a couple of months ago and I'll try to get around to doing it again to see if it made any difference.
Old Mar 5, 2013 | 03:23 AM
  #23
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You are incorrect.
If you get a matching key with a used ecu, you will not need dealer reprogramming.
If you SELL a used ecu, grind the key cut off so the key cannot be used to come back and open your doors or unlock your ignition. The buyer only needs the chip, not the key.
Old Sep 5, 2013 | 05:13 PM
  #24
ace!'s Avatar
Originally Posted by Billman250
You are incorrect.
Sorry to bring up an old thread, but I wasn't able to find a clear answer... It's been said that simply placing the key next to the ignition key won't start the car... So if one has the matching ignition key with a used ECU, how are you able to start the car using the original key in the tumbler?
Old Jan 6, 2016 | 06:17 PM
  #25
JUSTINTHECOASTIE's Avatar
Originally Posted by ace!
Originally Posted by Billman250' timestamp='1362486221' post='22381142
[quote name='schhim' timestamp='1362455606' post='22380652']
You are incorrect.
[/quote]
It's simple. You need the 00 ECU and 00 key to be from the same car. The ecu and key must match
Old Jan 6, 2016 | 06:51 PM
  #26
UberDuper's Avatar
In the service manual they tell you to tape the ecu matched key to the ignition matched key when testing a replacement ecu.
Found it. Ohh. Further reading says to cut a temp ignition key from a non-immobilizer key blank. So prob can't have two immobilizer keys in proximity.
Old Jan 9, 2016 | 02:38 PM
  #27
Apex1.0's Avatar
For me, I just drove my 00 car to the Honda dealer with an 03 ecu and nothing else. They charged me 1/2 hour to install the ecu an code my keys to the new ecu. That's it, done.
They gave me my old ecu uninstalled. Do a search on my old threads and you will see my review. The difference is subtle but noticeable.
Good luck
elksman
Mar 17, 2013 07:43 AM
Trigun
Jan 7, 2010 04:46 PM
robrob
Apr 26, 2009 06:32 PM
Envied
Aug 11, 2007 10:52 PM
APEXSEAL
Jun 1, 2006 05:09 AM
