Clutch sometimes slips after shifting
Old Feb 17, 2005 | 02:50 PM
  #21
slipstream444's Avatar
[quote name='Squeezer' date='Feb 17 2005, 09:02 AM'] why are you guys going with a stock disk?
Old Feb 17, 2005 | 05:36 PM
  #22
Gernby's Avatar
Former Sponsor
Originally Posted by slipstream444' date='Feb 17 2005, 05:50 PM
As you know, the disc doesn't 'grip', that's what the pressure plate does.
What do you define as "grip"? From a physics standpoint, the flywheel, PP, and FD all "grip" equally. It's all about the coefficient of friction between the surfaces baby!
Old Feb 18, 2005 | 09:29 AM
  #23
True Gernby. It's all about how all the parts work together.
However, with all things being equal, he won't gain much if anything by going with a non-OEM disk with the other parts involved remaining the same.
In other words, he may want to start looking at an entirely new setup to get the 'grip' he desires.
Old Feb 18, 2005 | 01:39 PM
  #24
Gernby's Avatar
Former Sponsor
[quote name='slipstream444' date='Feb 18 2005, 12:29 PM'] True Gernby.
Old Feb 20, 2005 | 05:20 PM
  #25
Elistan's Avatar
Success! The '03 slave cylinder went in Friday. (Although I had a brain fart and ended up trimming too much off the alignment peg - no big deal, just gotta make sure the hydrolic line doesn't get all wack when I torque the banjo bolt down.)
The car now feels like an '03 when shifting. Even doing fast redline shifts from 4th to 5th there's no slippage - the engine simply falls to the proper rpm and continues accelerating. It's great, I like it a lot.
Oh, and regarding the friction disk thing - comparing a car with Comptech flywheel, SPEC kevlan friction disk and SPEC pressure plate to a car with Comptech flywheel, OEM friction disk and ACT pressure plate (hardtopguy's offering, I think) - personally, I liked the OEM setup better. It still has that quick, strong, positive bite that the pressure plate gives you, with none of the on/off, bite-you-in-the-ass quality that the aftermarket friction disks have.
Old Feb 21, 2005 | 06:34 PM
  #26
kmvguy83's Avatar
i changed mine 2 month ago...
best upgrade for an 04+
dont wait til you change the clutch...
this takes about 30 mins... very easy!!
only hard part is the bleeding
Old Feb 21, 2005 | 06:46 PM
  #27
Elistan's Avatar
Pictures:
https://www.s2ki.com/forums/index.ph...ic=270439&st=0
rocsix
Nov 17, 2010 03:19 PM
clawhammer
Nov 5, 2007 09:10 PM
rocrfella
Oct 6, 2007 04:34 PM
rev28ktoy
Sep 4, 2006 07:12 AM
Howie
Mar 27, 2001 03:19 PM
