help! keyless entry doesnt work.
Old Oct 27, 2009 | 09:44 PM
whasupman's Avatar
Default help! keyless entry doesnt work.
Hi. My name is Kay. I bought my car last winter and never received the key fob that is programmed to my car. So then I found a honda key fob and tried reprogramming procedures that was given on this forum.
But I have no idea why the keyless programming is not working. The procedure says that when I repeat for the 4th time ( putting ignition to on then pressing "lock" within 1 second), the door lock is supposed to make a "clunk" sound which tells that the keyless entry is in program mode. However, no matter how many times I try, I cannot get it to work.
My doors, trunk, hood, and everything I can think of on my car that opens were closed. My keyfob had battery.
I was also wondering, after realizing that I have the Honda factory alarm system, if the the cars that are equipped with the alarm system has a different way of programming the keyless entry.
I actually gave up on programming it myself and decided that I should take it to the dealers soon. I was just lazy and never went for almost a year now. And I thought maybe someone here had similar problem and can enlighten me with some advices and insights.
I've had the car for about a year now and also have carried the non-working keyfob for the past year. Please help me fix my keyless entry!!
Old Oct 28, 2009 | 11:50 AM
littlerocket777's Avatar
First of all, are you sure the key fob is for a s2000? The code in the back should be something like E48J...something like that. If that's the case, then if I remember correctly, if your car has a factory alarm it does use a different type of fob. So that's your next step.
jbird0007
Nov 30, 2012 08:17 AM
badboy00z
Nov 29, 2009 12:33 PM
whasupman
Nov 2, 2009 08:38 AM
623baller
Apr 8, 2007 11:31 PM
FitzyS2k
Dec 11, 2006 07:19 PM
