Need CEL help
Old May 25, 2012 | 11:13 AM
cdelena's Avatar
Default Need CEL help
I wound up with a 'P0122 Throttle Position Circuit Low Input' yesterday during normal street driving. I did notice on the way home that throttle response was different so this is clearly something I need to address (just turned off the light for now).
The TB on this car ('00 AP1) was replaced about ten years ago and as I recall there was a procedure to adjust the voltages but it doesn't seem that they should change over time.
Any experience or advice?
Old May 25, 2012 | 02:04 PM
SpitfireS's Avatar
There is no mention about adjusting.
Just meansuring.
Out of the service manual:
Check throttle position angle with scanner.
In my software its called SAE.TP
It should be between 6% (closed) and 90% (open)
Why it isn't 100% at fully open is something I've wondered about, anyway..
Switch ignition OFF.
Disconnect TP sensor.
Switch ignition ON.
Between pin 1 and 3 - to outer ones - of the cable connector should be around 5V
Wire colour GRN/YEL = pin 1 and YEL/BLU = pin 2.
TP sensor side:
Resistance between pin 1 and pin 2 (= middle one) should be 500-900 ohm with throttle closed.
Around 4500 ohm with throttle open.
OR THE OTHER WAY AROUND.
I know this sounds a bit silly but I just noticed an error in my service manual.
They mention throttle fully closed at both measurements.
Probably something got lost in translation.
And.. check all grounds.
Allthough the TP has a 3 pin connector so most likely uses no engine ground at all.
I hope this helps.
Old May 25, 2012 | 05:04 PM
cdelena's Avatar
Just meansuring.
Switch ignition ON.
TP sensor side:
I hope this helps.
Thanks!
I got a response quickly from Proflow (great service on an old part) who said I should look for 660 ohm with a closed throttle but suggested I may need a replacement if it reoccurs. I've reset the code and it works normally so I'll just drive it for now.
Old May 25, 2012 | 07:43 PM
cdelena's Avatar
Now that I see the cost of a new TB I am not so happy... has anyone figured out how to replace just the position sensor?
Old May 25, 2012 | 10:36 PM
SpitfireS's Avatar
https://www.s2ki.com/s2000/topic/589...#entry13357892
Not trying to be a smarta$$ but I just typed TB position sensor in the search field in UTH.
Your post was #1
The link was #3
Old May 26, 2012 | 08:17 AM
cdelena's Avatar
Your post was #1
The link was #3
Thanks again... I stopped fighting with search years ago and obviously it no longer takes a fight so I should amend my expectations and habits.
That is a great solution and post from S2KART four years ago. That is the direction I will go and will report back.
Old Jun 5, 2012 | 12:08 PM
cdelena's Avatar
Update: tested the TBS and found it was marginal with only half the spec voltage in the closed position when the ambient temp is low.
Ordered a Omni-Power S2000 TPS Sensor ($64.00) and it works well and even gives a little smoother throttle response at low rpm.
Turns out this was easier for me since the pro-flow TB I have on the car already had replaced the TBS and screws so I was able to remove the sensor and replace without removing the TB and jacking with the tamper-proof screws.
AP2_s2000
Jan 23, 2017 04:19 PM
TruenoMike14
Nov 12, 2012 12:33 AM
Bigmanslim
May 20, 2010 02:54 PM
mookmerin
Feb 14, 2009 07:45 AM
Armand
Jan 25, 2008 01:31 AM
