Passport Radar
Old Jun 25, 2008 | 07:52 AM
si2die4's Avatar
You are going to wanna connect it to a fused power source. Having it hooked up where it is now will NOT cause any false alarms. Sounds like you may have a faulty unit.
Old Jun 25, 2008 | 08:02 AM
si2die4's Avatar
This may help: http://www.s2000.org/mods/radar/
Old Jun 25, 2008 | 08:06 AM
HankookS2K's Avatar
u need to connect it to an accessory line, best place is under your dash at the ignition harness. or you could relay it from your accessory line off your factory harness for the cd player.
the reason it keeps going off whenever it feels like it, is NOT because of the power source, its a common problem with the 8500 passports, send it back to escort for service. or even better, buy the 9500i
Old Jun 25, 2008 | 10:37 AM
innovation's Avatar
Originally Posted by beeza,Jun 25 2008, 08:37 AM
I've left my radar in the car for years, then again I dont live in LA like you do. Pretty safe here in Houston and I do put my top up when i park in public places anyway.
bad thing about LA its a hassle but just gotta get use to it
Old Jun 25, 2008 | 06:30 PM
roflitzjinno's Avatar
find a nice ground and i did that add a fuse trick with the radar and you can get it from autozone or pepboys.
Old Jun 28, 2008 | 04:18 PM
beeza's Avatar
That was my problem . I didnt really think about it till you said find a "nice" ground. Apparently I didnt , its all good now tho. Thanks
Old Jun 28, 2008 | 05:00 PM
R3DS2K's Avatar
radar detectors in LA.. lol when do you get a chance to speed lol.. and most drivers in LA do bout 80-85 on the freeway when they can anyways lol
Old Jun 28, 2008 | 10:14 PM
innovation's Avatar
still a expensive ticket my friend
Old Jun 29, 2008 | 04:13 PM
CFactor's Avatar
The laser issue is a known part of the Escorts. It happens in my s2000, my brothers TL, a coworkers neon etc. There is a recall that is free if you're still under warning. I just turned laser off, because laser can only be detected at VERY close proximity to the beam.
Old Jun 29, 2008 | 04:23 PM
slipstream444's Avatar
The issue with both the 9500i and the 8500i is sometimes related to actuation of certain electric devices such as electric motors.
I currently have the 9500i and previously had the 8500i and both would sound the laser alert when I adjusted the side view mirrors. The 8500i would do it for the right mirror and the 9500i for the left - and they were both mounted in the same spot. I have a friend that said his would some times go off right after start-up, aparently due to the air pump. Try choosing a different mounting spot just in case something near its current location is causing interference.
J_STATUS
Aug 4, 2008 04:23 PM
edmundo528
Florida For Sale
Mar 13, 2008 05:14 AM
identity_sh
Oct 4, 2005 11:23 AM
Filthy Beast
Feb 29, 2004 12:35 PM
mwy23
May 21, 2002 07:28 PM
