thermostat
And you should read the post you linked. Did you try the bleeding method outlined in the post you just linked?
Make the radiator cap the highest point in the cooling system and TA-DA! that's where the air will be. Since you have a heater, be sure to have that set all the way in the red.
Jacked the front up in the air.
Ran it up with out the rad cap on.
Kept bleeding air out of the head bleed point every few mins.
Put the cap on and brought it up to pressure.
All seems to work well now!
Originally Posted by funkemonke,Dec 7 2008, 06:32 PM
hondabond around thermostat housing
hope this helps, gl!
well i feel stupid!!!!!!!!
i went at it for 2 hours today and nothing.....
i even put a hose on the heater side to pressure the system and to flush it....
still the bottom hose is freezing cold...
RoninS2k
Apr 13, 2014 10:09 PM
