tips on oil pump replacement.
Old Aug 12, 2010 | 02:24 PM
ChefJ's Avatar
Default tips on oil pump replacement.
I am just looking for some tips on the oil pump change. I don't plan on pulling the head I would like to just do it by removing the chain cover oil pan and whatever other pieces absolutely have to be removed.
Any tips on what will need to be removed in order to get to the pump
Old Aug 12, 2010 | 02:27 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have done it with out head removal.
Remove:
oil pan
crank pulley
water pipe that crosses timing cover
be precise with your bead of hondabond for sealing the upper chaincase (where the timing cover meets the cyl head)
The rest you can prolly figure out.
Old Aug 12, 2010 | 02:44 PM
ChefJ's Avatar
so the alternator and those items are fine where they are?
This may not be as bad as I thought it would. I have deleted the ac and most of the other things that may be a pita already. Cool.
Do you recommend the stock oil pump? And if I went with an 04+ version is it a straight swap?
Old Aug 12, 2010 | 02:56 PM
Billman250's Avatar
Top Answer: 1
Make sure you get the updated pump. Search the board. There was a part number change in mid-late 2003. I did mine years ago. Hardtopguy posted the new number years ago. As a matter of fact, I have the box in my garage. I could ck tomorrow.
To go through the trouble, you definitely dont want some old stock pump.
Old Aug 12, 2010 | 03:01 PM
ChefJ's Avatar
^ yea as I have updated the oil jet bolts already. plastigaged everything and its all well within spec. I have straight 50 wt oil in a new built motor and I'm idling at 24ish pounds but it maxes out at 60 pounds. Its actually falling out of vtec after about 7500 rpms.
I probably did some damage to the pump with the bits of my piston ring before the rebuild. Should have had a new ne put in then.
Old Aug 12, 2010 | 03:05 PM
spets's Avatar
Whoa, why are you running a 50 weight? Should be a 30 weight oil.
Old Aug 12, 2010 | 03:33 PM
ChefJ's Avatar
Its a fully built motor with 9:1 compression. not stock. FI motors are built "looser" and I also track it so a good redline oil that doesn't shear at high temps is what I need and use.
Old Aug 12, 2010 | 05:39 PM
ChefJ's Avatar
pump part number 15100-PCX-023.
pasting for future reference.
That is the updated pump number.
Old Apr 14, 2011 | 06:06 PM
ChefJ's Avatar
bumping for any other tips. Its in the process now. will be attempting to remove the crankshaft pulley tomorrow.
braeden
Feb 9, 2015 11:51 AM
jjost15
Feb 10, 2012 05:30 AM
s22k000
Aug 26, 2011 02:36 PM
mikey k
Jan 20, 2010 09:58 PM
