Wheel Fitment Guide
Old Jan 18, 2017 | 08:49 PM
  #1311
sojirovs's Avatar
So, what would be RPF1 and tire size that do not require fender roll?
From the chart, rear can be fitted with 245 size tire with 17x9+45, but I can't seem to find the right size for front because RPF1 doesn't make higher offset than +45?
Please correct me if I am wrong.
I may be able to do very minor fender roll, but I really don't want to go with that route.
Old Jan 18, 2017 | 10:05 PM
  #1312
Manga_Spawn's Avatar
Site Moderator
You are right. There really isn't a combo that doesn't require a fender roll with the rpf1's.
Old Jan 19, 2017 | 07:05 PM
  #1313
sojirovs's Avatar
Which 17 inch track wheels offer 225/255 tires to fit without fender roll?
I want to find a set close to RPF1 price range
Old Jan 20, 2017 | 08:11 AM
  #1314
Site Moderator
The Enkei PF01's as they come in near OEM offsets. I think there is some OZ options that don't require a fender roll.
Old Jan 20, 2017 | 01:16 PM
  #1315
Kami Speed's Avatar
17x8.0 +50 / 17x9.0 +60 Enkei PF01. I have a brand new set of Black ones in stock.
Old Feb 24, 2017 | 10:29 AM
  #1316
sea206's Avatar
will fender rolling be needed for:
fronts : 17 x 8 +47
rears : 17 x 9 +47
setup?
Old Feb 24, 2017 | 03:05 PM
  #1317
Tartastic's Avatar
fronts : 17 x 8 +47
rears : 17 x 9 +47
setup?
For the rears, yes. Not sure about the fronts.
Old Feb 26, 2017 | 10:58 AM
  #1318
Site Moderator
Yes to both if you are lowered. At stock ride height you may not but it could still rub under the right situations.
Old Mar 8, 2017 | 03:30 AM
  #1319
k3ns2k's Avatar
Default Regamaster evo
Hi guys,
I am new here, about to get this set, size 17x8 +25 17x9 +38 with nitto neo gen 215/34 and 235/40/17. What will you guys think, it will fit on my 02 Ap1? Any fender will need to roll or pull in order to avoid rubbing against the stock fenders? I am also looking to use advan s-drive tires? Opinions?
thanks
k3ns2k
Old Mar 8, 2017 | 11:57 AM
  #1320
s2000Junky's Avatar
Originally Posted by k3ns2k
Hi guys,
thanks
k3ns2k
Wont fit up front without wide fenders. Need to reduce that offset to around +40 minimum. The rear will fit with a fender roll and stock 245's.
