another blown 2nd gear thread
Old May 30, 2013 | 04:29 AM
  #191
JoeyBalls's Avatar
I wonder if my 2nd gear is still alive after over 30 passes at the strip is because I never do a hard roll from 2nd gear? When I'm at the drag strip and go into 2nd the car already has a lot of momentum so it's less "dead weight" that 2nd gear has to move?
I don't know, I may be completely off but I think slowly rolling and hammering it in 2nd gear puts a ton of stress on it.
Old May 30, 2013 | 09:27 AM
  #192
siadam's Avatar
What exactly is breaking 2nd? The gears are stripping off or what?
I broke a countershaft in my 99 Si once, it was from wheel hopping though.
Old May 30, 2013 | 02:04 PM
  #193
neeman77's Avatar
Strips the teeth off the gear for second; this was my tranny when I took it apart:
Old May 30, 2013 | 08:31 PM
  #194
Boss-S2K's Avatar
Wow I must be pretty lucky. I'm making about 430whp and 300wtq. I've been doing 1st and 2nd gear pulls for over a year now. Maybe 4-5 times per month. 17psi. I do my highway racing starting in 2nd too. No issues yet, well besides not being able to get into second but I feel as if that is driver's error. I hope my luck remains. I feel as if I should stock up on another transmission.
Old May 31, 2013 | 05:03 AM
  #195
cmn's Avatar
cmn
I'm at 462whp/468Nm. I do pulls from first and second all the time, maybe several times a day (I don't have this car with this hp to cruise around at 30mph)... No issues so far after a few thousand miles at least. My transmission is still the original one from when the car was new, and has about 112000 miles on it. It has taken a lot of abuse from before the car was turbocharged as well. But I don't do launches from standing still or something, and I don't slam gears.
I do have a spare transmission for if/when my stock trans goes out though.
Old May 31, 2013 | 08:56 AM
  #196
siadam's Avatar
Awe, ok. Doesn't look to bad to fix. I'm sure the bearings/etc are ok, you could just press off the gears, and press new ones on.
I bought a press for that very thing when I broke my tranny in the SI. Bought a used countershaft for $60 bucks, replaced a couple bearings while I was in there, and fixed the whole thing for <$100.
Back on the road in a weekend.
Old May 31, 2013 | 09:04 AM
  #197
herecomesboost's Avatar
At what level does the case split? Meaning, at what point will a drop in gear set not be worth it? I've read that S2King ran a drop in gear set when he was dipping into the 8's. Anyone have additional (tangible) info?
Old May 31, 2013 | 11:00 AM
  #198
JoeyBalls's Avatar
I heard 650 -750? I want the PPG dogbox because it sounds awesome and you can really slam it in there but holy shit are they expensive!
Old May 31, 2013 | 11:25 AM
  #199
//steve\\'s Avatar
Had a PPG setup in my first WRX and loved it. Nothing like being able to beat on the car and not worry of the trans breaking.
Old May 31, 2013 | 12:22 PM
  #200
Boss-S2K's Avatar
Unfortunately, after eliminating the transmission as a weak point; comes the diff.
