another blown 2nd gear thread
Old Feb 9, 2012 | 03:46 PM
  #51
illestrolla's Avatar
Originally Posted by sata3000
My 2nd gear went today...booo
I hate reading this thread......
How hard do you drive the car?
Old Feb 9, 2012 | 03:51 PM
  #52
sata3000's Avatar
I really don't beat it up. I hit 14psi in 2nd so I believe thats the reason why. I think I'm going to do the supra option. Getting all my ducks in a row before I pull the trigger.
Old Feb 9, 2012 | 03:58 PM
  #53
When you say you hit 14psi in 2nd(which from your sig is over 300tq), was this a one time thing? Or often.
Old Feb 9, 2012 | 04:16 PM
  #54
sata3000's Avatar
I have hit 14psi often in second gear..I hit second gear hard. I didn't think it would go out. I was ignorant to the fact that it would go.
Old Feb 9, 2012 | 05:00 PM
  #55
jpetch05's Avatar
I'm shittin my pants reading this thread. I always hit 14 psi in second. What would be a second gear safe number ? I make 425/430 on 14 psi and a gt3076r afi setup
Old Feb 9, 2012 | 06:00 PM
  #56
miguel329's Avatar
you can get dash speedo to work think lj you need 12volt signal for the vss instead of 5volt.... i forget but ask him
Old Feb 9, 2012 | 06:18 PM
  #57
FullBlown's Avatar
Former Sponsor
We are working on a solution for that. Converting the signal to output 5 volts is very easy but you will need a way to adjust the pulse to match the gearing.
Old Feb 9, 2012 | 06:52 PM
  #58
S2SEXY's Avatar
what about the clutch setup if you run the supra tranny,and what about the driveshaft?
Old Feb 9, 2012 | 06:57 PM
  #59
CKit's Avatar
Could you adapt the "yellow box" people used for 4.57 gears to correct the speedo?
Old Feb 10, 2012 | 05:04 AM
  #60
sata3000's Avatar
I found an OEM trans with lifetime warrenty for 1500$. I think this will be my cheapest route. Once install I'll just lower my boost in 1st and 2nd and call it a day.Supra trans is a lot of $$$ and I'd still would need a diff to launch it.
