Getting ready to install! turbo
Old 05-24-2007, 12:47 PM
spoolins2k's Avatar
Thumbs up Getting ready to install! turbo
Ok I have my entire setup ready minus a couple of small things. I want to control boost through the aem ems, so do I need to purchase a gm boost solenoid?? Also I need a map sensor 3.5 bar should be fine, any suggestions on what to buy or where??? Thanks
Jason
Old 05-24-2007, 01:15 PM
EG-B18cR's Avatar
yes you need the gm boost solenoid and gm map sensor
Old 05-24-2007, 01:21 PM
Spoolin's Avatar
The GM boost controller and MAP sensor are junk. Spend a little more money and buy all AEM controllers and sensors. You will be much happier in the end.
Old 05-24-2007, 05:40 PM
afwfjustin's Avatar
Aww don't say that.
Old 05-25-2007, 05:27 AM
Spoolin's Avatar
Originally Posted by afwfjustin,May 24 2007, 08:40 PM
Aww don't say that.
It's true though.........I've seen to many people have problems with them. If you want to do it right, spend the extra money and buy good stuff. Seriously, the GM boost controller is known for causing real bad boost creep and the 3 BAR MAP is known for failing all together and that's very very bad.
Old 05-25-2007, 06:22 AM
geists2k's Avatar
Get the AEM stuff.
I had the GM boost control solenoid and after about ~1500 miles it would no longer control boost. I was over boosting ~16psi with boost set to 12psi in the EMS.
Not good. I didn't blow the motor, but it could easily happen.
Old 05-26-2007, 02:00 PM
afwfjustin's Avatar
Damn that sucks... I was about to order a GM boost control solenoid too. I already have the 3 bar map but it looks like I might have to make some changes.
I don't want to pour any more money into this car!!!
conors2k
10-07-2014 05:01 PM
03silver2000
04-28-2008 06:28 PM
CourageOO7
02-20-2008 05:15 PM
freshs2k
11-15-2007 01:16 AM
Gernby
11-25-2003 12:29 PM
Quick Reply: Getting ready to install! turbo
