Greddy emanage success with comptech SC
Old Sep 22, 2010 | 09:58 PM
  #41
s2000Junky's Avatar
Originally Posted by urBan_dK,Sep 22 2010, 09:17 PM
LOL...that's until I get a 7 psi pulley...just having the damnedest time finding a 4 inch or 3.8 pulley. No one seems to make them.
I sold my 4" already... but I do happen to have a 3.8" sos pulley if your interested.
Old Sep 22, 2010 | 11:22 PM
  #42
urBan_dK's Avatar
Um....yeah! I'm totally interested. Might be a bit over 7 psi but I'm hoping I have enough extra duty cycle to handle it.
Old Sep 22, 2010 | 11:51 PM
  #43
s2000Junky's Avatar
Yeah you will likely see 8psi. Will be a nice bump for you. PM me and we can work it out.
You have some timing you can play with... so retarding it will surely aid you if it turns out your lacking a little fuel. Should reduce your afr some and give you a bit of a buffer with any possible detonation tendency. Though I will tell you from experience, unless your car is running really high AIT from racing around, you wont ever detonate with this pulley if your running 12.5afr or richer... due to the nature of the SC linear boost with factory timing map. At 10psi I started getting some audible detonation pre vtec so I went back to 9 psi. If my methanol would inject quick enough I could run several pounds more boost, but it wont... so I'm playing it safe. Still cant complain about my output for what I'm using to mange things. Its kind of fun to feel like your cheating lol
Anyway enough chit chat, at 8psi you will be in the 325whp/215trq range which will be a nice bump. You are lucky if your making 280whp now.
Old Sep 23, 2010 | 07:48 PM
  #44
Seattle2k's Avatar
Originally Posted by urBan_dK,Sep 16 2010, 02:56 PM
BTW, Giles is (was) the foremost expert, unfortunately Ballistic Motorsports has ceased to exist, so no way to get his help now.
The other expert is mugenrios2k and I am rapidly becoming the local EMU apostle, I've already helped one person rewire their fubared Greddy harness and terrible tune (i.e. 7 degrees timing advance WOT at max RPM).
Giles' company was Holyroller Dyno, which has closed its doors. Twiztid (Scott) runs Ballistic and is very much still in business.
Old Sep 24, 2010 | 02:03 PM
  #45
s2konroids's Avatar
Guys, would 550cc injectors with bolt on's (Exhaust, header, HFC) be sufficient for a 11psi setup?
Also does the 'SOS' map sensor work with the greddy emanage ultimate?
Cheers
Old Sep 24, 2010 | 02:21 PM
  #46
urBan_dK's Avatar
I'd go with 650's to be safe if you stay at stock fuel pressure. Using an FPR you could get away with it.
Old Sep 24, 2010 | 02:24 PM
  #47
urBan_dK's Avatar
Cheers
You can use any MAP sensor you want as long as you base the y axis of your map off voltage and not PSI. Figure out the equation for translating the voltage from that sensor to PSI and you're set. I'm about to do this with a 3-Bar I got from PLX.
Edit: But you won't be able to ditch your factory sensor because the ECU will still want that signal to stay happy in closed loop.
Old Sep 24, 2010 | 02:30 PM
  #48
s2konroids's Avatar
I thought they was a limit the greddy could control? or is it 650cc?
Old Sep 24, 2010 | 02:50 PM
  #49
urBan_dK's Avatar
There was a limit with the Blue unit, but not the EMU, as far as I know. I'm planning on controlling ID720's with mine.
Old Sep 24, 2010 | 02:51 PM
  #50
s2konroids's Avatar
Interesting thanks
Going to download software to have a look at the feature and familiarise myself.
pinoyk20
Apr 30, 2008 07:59 AM
Psilos
Κινητήρας - Μετάδοση - Περιφερειακά
39
Sep 24, 2007 01:30 PM
Venomous S
Aug 12, 2005 08:39 PM
evf2000
Sep 24, 2004 05:54 AM
Maca
Apr 19, 2004 02:56 PM
