ID1000's and e85
Old Dec 25, 2014 | 12:42 AM
  #31
Dragi4aS2K's Avatar
502 whp on E85,id1000,Aem 320 lph,stock fuel lines,stock fpr no issues for the moment.
Old Dec 25, 2014 | 07:45 PM
  #32
Hershey's Avatar
What turbo and manifold?
Old Dec 29, 2014 | 11:50 AM
  #33
Dragi4aS2K's Avatar
Turbonetics* F1-57 Turbing Wheel.
* Turbing Housing: .65AR .Turbine Wheel Diameter: 64.89MM/62.07MM.
* Compressor Wheel: H-61
* Compressor Cover Size: 60 Series. Compressor Wheel Diameter: 61.41MM/81.99MM.
Mani from JS-Design Custom exhausts
Last update: valve dropped
Old Dec 29, 2014 | 02:39 PM
  #34
Prokaw875's Avatar
Originally Posted by Killer_B
Last night I added -6 fittings to my stock rail so I can add the inline pump and FPR.
This is what you need to do to retain your ID1000`s if your gonna want more power. Do an inline bosch 044... the 340 intank... FPR... crank that bitch to 100psi base pressure and youll be good for 600-650 on E85 no problem.
Old Dec 29, 2014 | 03:21 PM
  #35
Prokaw875's Avatar
Originally Posted by GTIWV
Im shooting for about 550 with my SOS kit on E85, I have ID2000's and a AEM 320lph pump and a AEM FPR. Will this be adequate or should I get the bosch 044 pump?
YOU`LL BE GOOD WITH WHAT YOU HAVE SINCE YOU HAVE THE BIG INJECTOR TO FLOW WHAT THE ETHANOL WILL REQUIRE AT A LOWER BASE PRESSURE. IF YOU DONT MEET YOUR GOAL ITS GONNA BE DAMN CLOSE AND I WOULD BE VERY SURPRISED. CAN ALWAYS ADD A 044 INLINE DOWN THE ROAD AND BE GOOD FOR 700 ON ETHANOL.
herecomesboost
Aug 8, 2012 02:53 PM
#1turbos2k
May 25, 2012 09:58 AM
Irishflame27
Dec 13, 2010 05:28 AM
1SickS2
Jun 4, 2006 07:12 PM
