Metallic slurry sound after cylinder head reassembly
Upgraded valvetrain and put everything back together and went to start the car and heard this metallic slurry sound. At first i thought it was a frozen pulley. I started the car without drivebelt, same sound. I did swap out oem to fluidampr pulley during the head upgrade so i will install oem pulley tmrw to see if that was somehow rubbing. Any ideas what might be the issue? I will undo cams and reinstall if the pulley checks out fine. Here is a video any help is appreciated headphone users beware:
Maybe the timing chain tensioner somehow got messed up during reassembly (had a hard time retracting it to reassemble it)aswell and is putting too much pressure on cam chain?
I think you answered your own question. I was running a ballade and it failed on me. Would not retract enough and made some weird noises...albiet, not the same as yours. I put back in a modified OEM and problem solved
It probably could be a lot of things, but when I went from my Ballade to BillMan’s my motor sounded silky smooth and silent. Just saying. I heard Ballade stuff might have been reformulated by now, so depends on how old it is. I did see the damage on one part of the Ballade TCT that could cause complete failure, it was a groove that was jus started to develop on one of the TCT parts but I don’t recall exact part name.
I had the ballade TCT for a year with no issues. Problem was when i took it out and back in basically it was difficult to make the worm gear rotate back into place via screwing in the 5mm(i think)bolt and wingnut. I removed it and just ordered an oem TCT and will eventually get a billman TCT when that starts to fail... Will report back if that fixes the engine whine.
only9k
03-31-2014 05:09 AM
