Official forced induction chat thread
Originally Posted by LordSovereign' timestamp='1422145214' post='23480362
^ both are technically heat exchangers aren't they?
Damn I bought the wrong kit!
Originally Posted by starrman' timestamp='1422145503' post='23480365
[quote name='LordSovereign' timestamp='1422145214' post='23480362']
[/quote]
In my attempt to find some decent IAT's I started considering the air/air...because once the water gets hot, well regardless of how big the pump is and how big the actual heat exchanger is (or one that will fit), it pretty much stays hot. But, I was warned by everyone that I would lose anywhere from 4 to 8 psi due to amount of pipe, so I never did it....BUT, depending on where you live you may never have an issue. I am in NC and we have many hot days in the summer.
As far as your other questions...The CT SC came with a FPR, which you will need, not sure about the ECU piece, I think there is some sort of piggyback system that will allow you to not invest in a standalone...I got an AEM V1 EMS. I started with the NOVI 1000. You should also look into getting a larger fuel pump as well. You can usually find most of these things in the Marketplace area on here...except for the CT FPR...I sold mine but it took me like a year. There was another guy who had one, but he did not have the bracket you need to mount.
Originally Posted by LordSovereign' timestamp='1422147387' post='23480397
[quote name='starrman' timestamp='1422145503' post='23480365']
[/quote]
[/quote]
So like you said, the water absorbs heat quickly which is good, but the heat is staying with the water too. I live in Oregon, so I should've gotten one with the aftercooler.
Yes the CT ESM is included in the kit, I think that's the piggyback system you're talking about. In regard to fuel system, do fuel injectors and fuel rail need to be upgraded after getting a larger fuel pump?
Originally Posted by poop-dog' timestamp='1422144374' post='23480344
Will adding a sc make my exhaust quieter? I believe I've read before that a turbo would but I imagine that's due to using exhaust to spool the turbo. Just curious and hoping the sc may quiet down the car a little.
Originally Posted by starrman' timestamp='1422144839' post='23480355
[quote name='poop-dog' timestamp='1422144374' post='23480344']
[/quote]
Don't you get more linear power distribution curve with the superchargers, hence it feels more "naturally aspirated" ? CMIIW
Originally Posted by starrman' timestamp='1422148815' post='23480422
[quote name='LordSovereign' timestamp='1422147387' post='23480397']
[/quote]
[/quote]
[/quote]
Right the ESM is the piggy back, the rail does not need to be upgraded and if you are just running the base pulley, I don't think you have to change out your pump or injectors.
Originally Posted by 8.5kallday' timestamp='1422154904' post='23480491
[quote name='starrman' timestamp='1422144839' post='23480355']
[/quote]
[/quote]
I thought the whole quieter exhaust was a joke... but since apparently it isn't...neither are going to really change the exhaust noise level. A SC sounds like a coffee can about half full of nuts and bolts being shaken with a bit of a whine in there as well. We all know what a turbo sounds like.
Btw, someone is selling skunk2 stage 2 cams pretty cheap. But I need to upgrade my valve springs and retainers, so I've come up with this skunk 2 alpha series springs and retainers
http://performance.importrp.com/i-18...fmvhoCjgDw_wcB
What do you think?
I personally would recommend changing your cams. There's been a lot of trial and error in the domain and nothing seems to be worth it. Especially reliability wise.
-My exhaust didn't get quieter with the sc.
-You will need a fuel pump but not injectors or fuel rail
-the ESM ain't a piggyback. It's just their to hide to boost to the oem ecu.
- I ran an water to air unit before. At the track after 2 runs and obviously 2 heat soak in between the water got hot to a point where my NA buddy was faster then me. I swap to an fmic (air to air ) and solve the problem. The "aftercooler " make a psi lost of about 0.5 psi. And with the fmic I saw a total of 0.8 psi.
So if you ask me ( I'm not a vendor ) I would choose an fmic anytime. Especially with that minus 0.3 psi of diference.
Maintenance is way easier without that f..king water , the engine bay is less full and it does not heat soak.
If you want to sell you fmic piping I got a friend who will take in right now
