Official forced induction chat thread
Sweet, thanks for the info. I'm on the Haltech PnP. Any negative effects if I remove just the soft lines and cap the ports and tee?
If I take an old primary o2 sensor and chop the connector clip off, can I wire it to my AEM wideband and utilize the factory harness to get the signal to my AEM series 1 EMS? Really don't want to hack into the factory harness to wire it in...
Edit: found this post by Stratocaster. So it can be done it seems. Has anyone else gone this route? If so I'd love to see a picture of the wiring. Electronics arent my strongest talent...
When it comes to sensors, ECUs and dataloggers (the AEM EMS is both) there is a referance 5v+, a ground and a signal lead. A wideband has a heater circuit as well. It is best if the ground for these sensors are controlled by the device and not body group. You could keep up witha floating ground that may differ from the control ground from the device. So itnis best to ground to C18.
For my install, I cut the connector from an old stock O2 sensor and wired it to that connector. Easier then opening and depinning the ECU connector.
Can I get solid answer if id1300 and walbro 416 e85 pump can support 600whp. Id told me if I use id2000 and the car sits longer than a few weeks I will have to remove the injectors spray with wd40 and pit in Ziploc bags. The id1300 are stainless and they said I could leave those on.
Who has made 600 with id1300s? My car is a weekend/summer car that may sit weeks at a time
Thanks guys
Thanks guys
Thanks guys
Thanks guys
Lude92, did, or are you going to build the head or block to support this new power?
Thanks guys
Thanks guys
Here is my personal results. This is with E85. Also notice it seems to be on the edge of the pumps capabilities.
Here is a usefull web app i used. http://webpages.charter.net/hybrdthr...mp_web_app.htm
This is what im coming up with.
With a base pressure @ 43.5 + ~22 psi of boost + ~ 5psi for pressure drop = 70.5 fuel press.
So ~580 crank hp (aprox. 500whp) * .84 (B.S.F.C for FI w/e85) =487.2 lbs/hr
So I should need aprox. 487.2 lbs/hr @ 70.5 psi
The walbro is showing to support 510.37 lbs/hr @ 70 psi
