Official forced induction chat thread
Old Apr 14, 2014 | 11:53 AM
  #611
2004TurboS's Avatar
I have a sidewinder manifold . I was looking Into making an intake that ran through the fender( where inline pro runs there intercooler pipe) to the bumper . Has anyone done this? What is the biggest pipe that can fit through there? I was considering getting a 4" to 3" adapter since 4" pipe seems big for there .
Old Apr 14, 2014 | 11:57 AM
  #612
baZurk's Avatar
4" will be way too large. 3" will be close. Most setups I see, people run ducting from the front grill up through that hole by the headlight to bring the cool air to the filter.
Old Apr 14, 2014 | 12:40 PM
  #613
2004TurboS's Avatar
I figured. The filter does get hot/warm. I'm sure some cooling for it will make a difference? Just have the filter right off the turbo now.
Old Apr 14, 2014 | 01:14 PM
  #614
omarisramo's Avatar
Who here has braced their turbo manifold? And if you have, what are you using? Helm Joints?
Old Apr 16, 2014 | 04:51 PM
  #615
2004TurboS's Avatar
Does anyone run 3" straight pipe with just a resonator or a dynomax race bullet?
Old Apr 16, 2014 | 05:09 PM
  #616
herecomesboost's Avatar
Even with a 3" intake, you'd need to remove the headlight brace/bracket.
Old Apr 16, 2014 | 09:50 PM
  #617
9KRPM2.0's Avatar
Is this legit? The part number matches the real deal but could this still be a fake?
http://www.ebay.com/itm/HKS-SQV-Supe...61d624&vxp=mtr
Old Apr 16, 2014 | 10:12 PM
  #618
redboost10's Avatar
Is this a pipe or tube manifold?
Old Apr 17, 2014 | 05:08 AM
  #619
spectacle's Avatar
If your manifold is cracking, bracing it probably isn't going to help. You need better welds.
Old Apr 17, 2014 | 05:16 AM
  #620
RAIN H8R's Avatar
Originally Posted by 5thgen
Originally Posted by RAIN H8R' timestamp='1397124314' post='23106114
We did try it. My friend is a bit more laid back and didnt want to drill a hole in his hondata gasket. We had issues bleeding the air out, and the car overheated after a 7 or so minute drive.
Sent from my SCH-R970 using Tapatalk
What did you try? Blocking the primary way to bleed air out of the head? Of course you would have issues. I thought the question was about removing hoses and not blocking the flow to the bleeder.
I never said I blocked flow to the bleeder valve. I said I removed the coolant hoses. My bleeder valve works 100% like it would from the factory.
AFK, you can remove your iacv/TB coolant hoses, just don't block access to the bleeder. I guarantee this will work as well as Honda intended.
Yes, he blocked the bleeder as left the hose on it. So it did not work very well as it was a dead end.
The question about removing the hose is also basically the same problem, you are indeed blocking the constant flow of coolant, and it is simply only a bleed location once you remove the hose. I simply do not understand why anyone feels it is necessary to remove the hose. Is it a "form" change? Does it look better or something? Because it is certainly not a function upgrade. I stated my uneducated, educated opinion, Im moving on.
You are correct on removing coolant flow from the IAC and TB, the car will function properly without them. The TB is literally a loop anyway,
