Official forced induction chat thread
Old Apr 30, 2014 | 11:16 AM
  #701
cmn's Avatar
cmn
Originally Posted by camuman
Originally Posted by baZurk' timestamp='1398866365' post='23137108
[quote name='cmn' timestamp='1398866119' post='23137096']
Hmm. Is he running the Stage 2? Maybe I could get away with a stage 2. It would be quite a lot cheaper. It would suck if it's not enough though...
To my knowledge he has the 1.5+
What are your plans for the car?
it all depends on what you are going to do with the car and how hard you will drive it. plenty have survived on oem stock original diff/trans combo up to 500-550 whp or about 350-400wtq. i am still on my original oem trans/diff after 20k boosted miles. 450/300 for power. but i dont slam gears are laucnh the car.
[/quote]
I'm at 500whp and nm. I drive the car somteimes to work, for spirited driving, and some trackdays (road track, not drag). I don't launch or slam gears, but I drive what most people say is relatively hard. I still have my stock trans with ~118 000 miles, but I have literally crushed the gears in 2 diffs under highway pulls (not launching or drifting etc). I think both were 2nd gear.
Old May 1, 2014 | 03:49 AM
  #702
BuggyofMildDiscomfort's Avatar
Gear life/wear/damage is very dependent on driving style and especially the roads/conditions you drive in - shock loads from dropping the clutch with grippy tyres, are immense, but so are shock loads from full throttle over a rough road if the tyres slip then grab on an edge.
Transmissions that would last 500bhp in a rally car for a season, and more than that for road use, don't last 3 months at 250bhp for us, yet someone that's not riding the car as hard might baby it out to a season if they drive knowing it's a weak link.
It's very hard to determine what is a safe power level because of that, and also because many who have no issues yet, could still be operating well into the fatigue zones for the transmission and just happen to be getting away with it for a little while.
Old May 1, 2014 | 06:19 AM
  #703
baZurk's Avatar
Just curious how many of you with aftermarket gear ratios use the yellowbox speedo fix. I'm starting to look into it now
Old May 1, 2014 | 06:49 AM
  #704
bruthaboost's Avatar
I have the carbonetic mission final drive, 4.45, and used modifry's speed corrector and I'm within one mph of accuracy against a GPS speedometer.
Old May 2, 2014 | 07:53 AM
  #705
2004TurboS's Avatar
Switching from an mbc to an ebc am I able to setup the ebc myself or is this something complicated? Mac solonoid is being used
Old May 2, 2014 | 08:08 AM
  #706
baZurk's Avatar
What ems? It is relatively simple to do. There is a lot of how to information for AEM units on this board.
Old May 2, 2014 | 08:24 AM
  #707
2004TurboS's Avatar
I have the haltech pro plugin ems
Old May 2, 2014 | 08:27 AM
  #708
camuman's Avatar
Originally Posted by CoolGuy094
Can someone tell me what this vacuum line is/does? It comes off one of the ~5/16" ports on the intake manifold and tee's off under the IM. One side of the tee goes to right after the throttle body into a gold stub. The other side of the tee goes down under the car somewhere. I'd like to remove/cap these ports if possible. Just need to know what they're for and where that other line goes down under the car. Is it emissions related?
i think its something to do with either emissions or that vent system for the gas tank. i left it as i had no idea what would happen if i eliminated it.
Old May 2, 2014 | 05:46 PM
  #709
herecomesboost's Avatar
^That's correct. I deleted them since AEM isn't looking for the purge solenoid anyway. You will see 3 metal (fuel) lines under the car; feed, return, evap/purge. The aforementioned hoses will terminate at the purge/evap line. Which EMS are you using?
Old May 3, 2014 | 06:21 PM
  #710
S2-Kai's Avatar
Anyone here familiar with the AEM EMS-4? I'm wondering if you can run the ethanol content sensor and have the EMS-4 adjust the ignition and fuel on the fly like the Series 2?
