Official forced induction chat thread
Old May 6, 2014 | 09:53 AM
  #721
omarisramo's Avatar
Originally Posted by baZurk
Which fuel?
93 octane
and probably either 110/6 octane.
thanks.
Old May 6, 2014 | 01:02 PM
  #722
Suprglu's Avatar
Just curious how many of you with aftermarket gear ratios use the yellowbox speedo fix. I'm starting to look into it now
Depends on your application. Mazda 3.9 is very popular. They are about $500 extra for a diff rebuild. But they give a very desirable amount of time in each gear.
Old May 6, 2014 | 01:09 PM
  #723
Suprglu's Avatar
Originally Posted by omarisramo
Using ID1000's, walboro 255 and efr7670, what numbers should i expect before maxing out the fuel?
What numbers are you asking about?
Old May 6, 2014 | 01:17 PM
  #724
Suprglu's Avatar
Originally Posted by cmn
Originally Posted by camuman' timestamp='1398866669' post='23137114
[quote name='baZurk' timestamp='1398866365' post='23137108']
[quote name='cmn' timestamp='1398866119' post='23137096']
Hmm. Is he running the Stage 2? Maybe I could get away with a stage 2. It would be quite a lot cheaper. It would suck if it's not enough though...
To my knowledge he has the 1.5+
What are your plans for the car?
it all depends on what you are going to do with the car and how hard you will drive it. plenty have survived on oem stock original diff/trans combo up to 500-550 whp or about 350-400wtq. i am still on my original oem trans/diff after 20k boosted miles. 450/300 for power. but i dont slam gears are laucnh the car.
[/quote]
I'm at 500whp and nm. I drive the car somteimes to work, for spirited driving, and some trackdays (road track, not drag). I don't launch or slam gears, but I drive what most people say is relatively hard. I still have my stock trans with ~118 000 miles, but I have literally crushed the gears in 2 diffs under highway pulls (not launching or drifting etc). I think both were 2nd gear.
[/quote]
Are you referring to a stage 2 clutch? Competition Clutch Stage 2 - Street Series 2100 Clutch Kit has spec that are good up to 300ftlbs of torque. This would not cover you for launching the car. But good for street or track. I bought one and will be running 420whp and 260ftlbs of torque.
Old May 6, 2014 | 02:03 PM
  #725
omarisramo's Avatar
estimated hp and if i upgrade the fuel pump will that yield higher numbers?
Old May 6, 2014 | 05:28 PM
  #726
herecomesboost's Avatar
Originally Posted by S2-Kai
Anyone here familiar with the AEM EMS-4? I'm wondering if you can run the ethanol content sensor and have the EMS-4 adjust the ignition and fuel on the fly like the Series 2?
Yes. You can run an ethanol sensor/switch fuels dynamically. EMS-4 uses the same software as v2 (AEMTuner).
Old May 12, 2014 | 05:59 AM
  #727
DaOne54's Avatar
Hey guys so I just threw my turbo manifold up, and my A/C lines are sitting right on my manifold... :'(
So I'll be needing some custom lines, I've looked around and there seems to be a couple different ones, i also noticed that theres a sponsor here that sells them.
Do you guys recommend any specific ones?
Thanks.
Old May 12, 2014 | 09:44 AM
  #728
s2klariat's Avatar
^^^ Ghettocrx a.c. relocation lines. If I had to relocate mine, I'd buy these.
Old May 12, 2014 | 12:16 PM
  #729
Redline S2K's Avatar
+1 for ghettocrx ac lines.
Sent from my Galaxy s5
Old May 12, 2014 | 12:19 PM
  #730
baZurk's Avatar
+1 I have them as well. I never recharged my system though. It's been almost a year o___0
