Official forced induction chat thread
Old Jun 3, 2014 | 10:29 AM
  #821
camuman's Avatar
Originally Posted by Redline S2K
What coolant setup are you running Camuman? I'm thinking I may need get some space between my intercooler and front bumper.
STOCK SON. stock radiator. giant fmic. still has AC. stock drivers side fan. summit bobo passenger side fan. both set in aem to come on once car is turned on. distilled water and water wetter in radiator.
key is bleeding the ever loving shit out of it. i only street drive mine, no road coarse stuff.
Old Jun 3, 2014 | 10:44 AM
  #822
Redline S2K's Avatar
I think I have some air in mine. Heat isn't as hot as I know it can be. May try installing the factory small fan back in.
Sent from my Galaxy s5
Old Jun 3, 2014 | 10:58 AM
  #823
When you say the fans turn on when the car is turned on, do you mean key power or at a certain temp they turn off and on? Also, I'm guessing, you don't have one turn on with the AC now just both with AEM?
Old Jun 3, 2014 | 11:08 AM
  #824
camuman's Avatar
sorry, key on fans on. no temp setting.
Old Jun 3, 2014 | 05:03 PM
  #825
starrman's Avatar
OK, I see as high as 190 while cruising at 80mph...I really don't encounter a lot of traffic, but you never know..I don't know how well the stock rad will hold up in 95 degree summer heat, sitting still. So I was going to go the Mishimoto route with the Xline (new super duper rad) along with the fans...now I see someone said don't use Mishimoto? Are there issues with that manufacturer...what is the scoop?
Old Jun 3, 2014 | 05:29 PM
  #826
Bazurk touched at it in this thread or his (can't remember) but most aftermarket radiators aren't much of an upgrade due to how the s2000 radiator is designed in the first place. I'd get the new koyo or throw down the cash for a dual pass.
As for my heat issue, I'm going to remove the black grill from my bumper to help air get around the IC. Also got some water wetter and going to mix it more distilled water.
Old Jun 3, 2014 | 05:40 PM
  #827
baZurk's Avatar
Right. To really upgrade you need to move to a dual pass unit. Otherwise you need to focus on getting as much ambient temp air to the radiator as possible. Using the fake brake ducts to funnel air around the intercooler could make a substantial difference in cooling capabilities at highway speeds.
Old Jun 3, 2014 | 05:41 PM
  #828
baZurk's Avatar
For those who see that there coolant is getting hot, turning on your heater fans will drop those temps substantially if needed. It is just slightly uncomfortable haha. Switch to the top vents and point them up and out/away from you.
Old Jun 3, 2014 | 06:11 PM
  #829
starrman's Avatar
Why Koyo over Mishimoto? and who makes a dual pass?
So your not saying there is anything wrong with the Mishimoto; you are saying that the OE rad is designed so well that replacing it with a 3 row core (bit larger) aftermarket rad is not going to let me realize much of a benefit?
Old Jun 3, 2014 | 06:18 PM
  #830
baZurk's Avatar
The misimoto/fullblown radiator is an upgrade from stock with proper fans. But it has the same design as stock which is truly inferior and not efficient at all. If you search in the racing forum you will see a link for some dual pass radiators. They are expensive though. The one with a built in oil cooler is over $1000. I don't know who else makes dual pass radiators for us.
