Official forced induction chat thread
Old Dec 10, 2014 | 11:08 AM
  #1321
camuman's Avatar
Originally Posted by spectacle
Originally Posted by 1SlowSi' timestamp='1418039287' post='23430308
What's on everyone's christmas wish list this year
CLUTCH
someone to grease my throwout bearing.
Old Dec 11, 2014 | 03:57 AM
  #1322
Sylvain2000's Avatar
I think you anwsered you own question but you dont want to listen to yourself.
- Since you cut most of the support i wouldnt use it.
-the aftermarket would work.
There you go !!
Old Dec 11, 2014 | 05:08 AM
  #1323
Redline S2K's Avatar
Originally Posted by mmmposta
So ive been working on my turbo install this week. Running a bottom mount pte 6262, the hot side is hitting against the passenger side motor mount bracket. I had to cut and shave quite a bit off the bracket to finally get it to fit properly with the turbo in place.
My question is... will I be fine with my oem motor mounts or should I run aftermarket motor mounts (innovative, hasport)? The motor mount design of those companies would give me the clearance I need for the turbo. Buddy was saying there's a chance my motor mount bracket will break since I basically cut out the top portion of it.
Would much rather keep my OEM mounts if I'll be safe with the bracket the way it is.
Post a picture of what you cut. It's possible you weakened it but also, if it fails, it could cause your turbo to contact the mount of something. I'm having trouble picturing exactly what you did though.
Old Dec 11, 2014 | 07:33 AM
  #1324
baZurk's Avatar
What's circled in red is what I cut.
I'll get the aftermarket mounts only if I really need it, but I'd read a few reviews about people saying how bad they vibrate and how loud they are.
I would advise against using the modified mount bracket. Cutting the section out will seriously decrease rigidity and strength of that piece.
Old Dec 11, 2014 | 08:09 AM
  #1325
CoolGuy094's Avatar
You don't have a before-after picture of what you cut away do you?
Old Dec 11, 2014 | 11:43 AM
  #1326
I wouldn't use that mount bracket. I feel it could bend with that piece cut off. I'd get a new one and look into getting a smaller cover for your turbo.
Old Dec 11, 2014 | 12:11 PM
  #1327
Honda_Mad's Avatar
Just a question on my graph, car doesn't seem to make any power past 7000rpm. Which doesn't seem normal to me for a f20c, any suggestions on what the issue could be.
F20c
9.1cr
Afi twin scroll manifold
Precision 6265 T4 .81ar
Unported head. 74mm throttle body
E95
33psi boost
Old Dec 11, 2014 | 12:36 PM
  #1328
The .81 AR exhaust housing could be choking the engine up top. Divided housing s2000's seem to perform better with larger housing. I'd try at least a 1.00. Smallest I've seen make good power on a divided T4 I think was Passman (s2ki member) using a large Borg turbo with a .91 or so.
Old Dec 11, 2014 | 12:43 PM
  #1329
Honda_Mad's Avatar
I also thought that it could be the housing choking. The manifold is divided but the turbo is a normal open T4.
Old Dec 11, 2014 | 06:07 PM
  #1330
No,that will not be enough.
