Post your Catch Can Setups
Old Jul 16, 2012 | 02:04 PM
  #161
Sarek's Avatar
Originally Posted by benlee02
Just got done installing my setup!
Are those -8 lines?
that does look clean! I'm still trying to figure out where to tap/weld...
Old Jul 17, 2012 | 01:00 PM
  #162
BoostinS2's Avatar
They appear to be, as I am running -10s on my setup.
Old Jul 18, 2012 | 11:05 AM
  #163
Sarek's Avatar
Originally Posted by Boofster
I'm seeing all these crazy nice valve cover setups for catch cans with bungs in random locations but I hope you guys are aware of the baffle.
I experienced this issue first hand at the track. Took the quick way and used a filler plug fitting temporarily.
Tons of oil ended up coming out from the catch can filter at high g's.
I know many of the cars above are not track driven but keep in mind this is a big deal.
Here is what the valve cover looks like underneath:
Once you inspect the baffling, you will see the complexity of the system.
The best (only fullproof) way IMO is to use the oem pcv locations.
I was thinking about this too. Although it seems most FI guys aren't getting much oil accumulation (or at least it's not being reported) venting from the sides, I was curious why hasn't anyone vented from on top, utilizing the OEM baffle (RED CIRCLES BELOW) vs the more common driver side (BLUE CIRCLES BELOW)? I wanted to do this. Would there be any reason not to, besides aesthetics?
http://www.flickr.com/photos/82936204@N03/7598678394/
Another cost effective option:
This uses a -12 Banjo and replaces your oil cap. Any thoughts? Anyone have experience with this?
I could only think of the "non-baffled" issue. But then again so is venting from the side of the VC.
"Used with breather tank kits.Runs a breather hose from the ' valve cover oil cap ' to the breather tank.
Fits : All Honda & Acura's 1988-2001"
http://www.z10eng.co...&products_id=43
Old Jul 18, 2012 | 11:46 AM
  #164
Boofster's Avatar
DO NOT use the oil cap cheat.
It's not baffled at all. I tried it once and oil spilled massively everywhere. FML!
Old Jul 18, 2012 | 12:03 PM
  #165
Sarek's Avatar
"...filler plug fitting" <-- That's what you meant! Duly Noted!
Would you agree that welding/tapping the top of the VC would be the most effective location for a baffled vent? I'm about to drill the holes today and wanted to see if there are any downsides
Old Jul 18, 2012 | 02:39 PM
  #166
herecomesboost's Avatar
No downsides to such a configuration
Old Jul 18, 2012 | 03:43 PM
  #167
Sarek's Avatar
Thanks!
Old Jul 18, 2012 | 07:51 PM
  #168
Boofster's Avatar
^ I would be concerned for hood clearance in that case.
Not sure what's the problem of using the two stock outlets.
Old Jul 18, 2012 | 10:20 PM
  #169
Sarek's Avatar
Originally Posted by Boofster' timestamp='[url="tel:1342669896"
1342669896[/url]' post='21871624]
The stock outlets are too small. My dipstick is still popping out. If your referring to stock locations for the AN fittings, it's a little tight IMO to weld a -10 fitting.
The hood clearance is a good point. I'm considering the banjo setup that z10 offers.
http://www.z10eng.co...af74168629b4999
I don't know how to post pictures with the iPad
Old Jul 19, 2012 | 03:46 AM
  #170
Nice find! Thanks for the link.
