Post your Catch Can Setups
Old Oct 14, 2013 | 03:47 PM
  #191
illestrolla's Avatar
Originally Posted by herecomesboost
^Does the third hose terminate under the car?
Yup. Actually both stock locations just vent to atmo under the car and I have yet to see any sort of puddling/leaks. The PCV is drilled and I had to do a little "mod" to get the braided line to fit snug on the stock PCV valve, but now all 4 lines are braided
Old Oct 15, 2013 | 04:44 AM
  #192
LilJoe's Avatar
Pipe tapped VC with -10 lines to a baffled catch can.
Old Oct 15, 2013 | 10:24 AM
  #193
jordannn93's Avatar
Looks good . What size fitting did you use in the Pcv hole?
Old Oct 16, 2013 | 04:42 AM
  #194
LilJoe's Avatar
1/2" NPT to -10AN 90.
Old Oct 16, 2013 | 07:17 AM
  #195
herecomesboost's Avatar
Clean setup LilJoe
Old Oct 16, 2013 | 09:45 AM
  #196
passmans2kny's Avatar
love the hardlines on that set up
Old Oct 17, 2013 | 06:07 AM
  #197
LilJoe's Avatar
Thanks guys
Old Jan 30, 2017 | 05:39 PM
  #198
skinsfn36's Avatar
Does anyone know the fitting for the PVC to -10AN?
Old Aug 26, 2017 | 03:54 PM
  #199
schhim's Avatar
Default My setup
I finally got around to installing my Saikou Michi catch can. I drilled holes in my crossmember to mount the cans.
Attached Thumbnails Post your Catch Can Setups-img_20170826_184647.jpg   Post your Catch Can Setups-img_20170826_184638.jpg
Old Dec 19, 2017 | 12:04 AM
  #200
visionxboy's Avatar
After 20 pages.. Just to be clear looks like most of you FI guys are running VTA instead of closed loop. Is there any dangers with running a closed loop? I might be able to get at the ASM/Cusco can, but its unable to vent to atmos. What to do?
