The Ultimate GReddy Turbo Kit Thread
Old Apr 28, 2011 | 01:56 PM
  #1081
Nyther's Avatar
Does a HFC prevent Backfire?
Does a HFC will create more drone?
Old Apr 28, 2011 | 09:42 PM
  #1082
TheChazz's Avatar
Originally Posted by Chris_Lum
Originally Posted by TheChazz' timestamp='1304013702' post='20517481
So, what about the restriction of a stock cat and exhaust setup? The cutout is not very pricey, around $160. Should I just go with a HFC? Will it yield the same results. I just DESPISE loud exhaust, thats all.
What 'same results'--What are your power goals?What exhaust do you think is loud? and which do you consider quiet?
Will a HFC and stock catback yield the same results as a cutout from the greddy kit. If I can achieve this on stock exhaust or even with just a HFC Ill go that route.
I prefer nearly silent exhaust. so loud to me would be anything that can be heard inside the cabin during DD.
thanks for the input
Old Apr 29, 2011 | 07:59 AM
  #1083
AFs2k's Avatar
Originally Posted by AFs2k
Originally Posted by itlynstalyn' timestamp='1304009514' post='20517172
They actually already make a T25 to 3" v-band, I'm using one.
Ok... who is they? Got any pics?
Again... who is "they"?
Old Apr 29, 2011 | 08:38 AM
  #1084
itlynstalyn's Avatar
Originally Posted by AFs2k' timestamp='1304027252' post='20518455
[quote name='itlynstalyn' timestamp='1304009514' post='20517172']They actually already make a T25 to 3" v-band, I'm using one.
[/quote]
Sorry, didn't see your first reply:
http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB
Old Apr 29, 2011 | 09:52 AM
  #1085
AFs2k's Avatar
Well, check this out.
I bought one of those to use on my turbo. It DOES NOT fit. The exhaust of the turbo is NOT an oval which is how the flange on those are made. Look at the top left picture they have in the series of 4 on that page you linked to. NO turbo in this size range has a oval outlet. It is more of a weird shape. It did bolt up because the bolt holes lined up, but other than that it won't work properly. I won't use it because of it not letting the wastegate full movement.
It would not allow the wastegate to actuate fully. Maybe had 3-4mm of opening which is not good because I measured 15mm needed to travel. I have 2 of these turbos so I used the one that is off the car so I could see this fully. I would have to cut a section of the flange to make it work.
So now, with all that said...
I am working with a very reputable company who has made quite an impact on the s2000 forced induction community. I shipped them my other turbo so he can make one with a specific flange that fits and allows full range of motion for the wastegate.
Old Apr 29, 2011 | 11:06 AM
  #1086
Ahhhhh, I got you. I have a GT3071 upgrade that's T25-flanged so I just assumed it would work. My mistake.
I believe the guy I bought this from ran into the same problems. The GT30 turbo has the wastegate door open in the other direction if I believe so.
Old Apr 29, 2011 | 11:35 AM
  #1087
AFs2k's Avatar
Do you know for 100% sure if it (ATP flange adaptor) works ok on the GT3071? I.E. no problems with the wastegate because it opens up instead of down?
Old Apr 29, 2011 | 11:47 AM
  #1088
Nyther's Avatar
My turbo - > downpipe gasket is torn.. does anyone know which one i need to order on ebay?
Thanks!
Old Apr 29, 2011 | 02:58 PM
  #1089
Chris_Lum's Avatar
Originally Posted by Chris_Lum' timestamp='1304023880' post='20518211
[quote name='TheChazz' timestamp='1304013702' post='20517481']So, what about the restriction of a stock cat and exhaust setup? The cutout is not very pricey, around $160. Should I just go with a HFC? Will it yield the same results. I just DESPISE loud exhaust, thats all.
[/quote]
hfc and stock exhaust would work best. you will likely overboost with a cutout.
Old Apr 29, 2011 | 05:21 PM
  #1090
TheChazz's Avatar
Ill look into it, I should not over boost with the cutout and a restriction plate, but I will probably go with a HFC for simplicity
