The Ultimate GReddy Turbo Kit Thread
Old Sep 2, 2009 | 08:26 PM
  #611
g352s2k's Avatar
Originally Posted by chad86,Sep 2 2009, 07:42 PM
Yah, a gt30 upgrade, Check this out
https://www.s2ki.com/forums/index.ph...ic=705184&st=0
I'm in the middle of doing this upgrade myself...
yeah whats up with the actuator arm??? is it possible just to bolt up, tune and go?
Chad keep us updated cause i want to do this next summer.
Old Sep 2, 2009 | 10:06 PM
  #612
chad86's Avatar
Check the link out now ^^^^^ I am doing larger injectors, 3mm HG, 3" DP. ( with meth).... And tune at about 25 psi.... Kepp an eye on that gt30 upgrade thread.. engineerX is doing a great job in that thread....
Old Sep 3, 2009 | 08:06 PM
  #613
1fastminivan's Avatar
oh wow, i wasnt aware of the "customizing" of the greddy kit haha. Thats awesome. I'm gonna keep my eye on those
Old Sep 10, 2009 | 01:46 PM
  #614
jari8378's Avatar
i got question....
I just got the greddy pressure sensor. I got it plugged into the option 1 port. How do i set it up correctly? are there settings to be adjusted? i did not find a guide or install manual
Old Sep 10, 2009 | 06:50 PM
  #615
cboyarskirn's Avatar
http://videos.streetfire.net/video/Marcs-t...-s2k_158519.htm
This is a video of a ap2 only with greddy kit and exhaust with 329whp on dyno... hope its not a repost...
Old Sep 11, 2009 | 02:55 PM
  #616
JoeyBalls's Avatar
Originally Posted by jari8378,Sep 10 2009, 01:46 PM
i got question....
PM Chris Lum
Old Sep 11, 2009 | 03:12 PM
  #617
Chris_Lum's Avatar
after plugging in the greddy sensor, select greddy pressure sensor under the drop down menu in opt port 1 (under front panel in the setup).
Old Sep 12, 2009 | 08:21 AM
  #618
sammy21c's Avatar
Could you guys send me AP2 base map? I bought it used and he sent me a base map but seems to be not running well. I just wanna compare or try. thank you.
sammy21c@hotmail.com
thank you.
Old Sep 12, 2009 | 08:49 AM
  #619
JoeyBalls's Avatar
Somebody Help him out, the I sold him My Greddy Kit and the Base map I sent him is giving him issues
Old Sep 12, 2009 | 10:14 AM
  #620
sammy21c's Avatar
Thank you Joe.
So far, here is my problem.
1. Coolant temp gauge on gauge cluster is 1 dim only (on e-manage, it is reading good)
2. while driving, passing between 4000-6000rpm, speedometer reads 0, eps light comes on. It can be reproduce whenever I pass by those range. I do have yellow box, (4.77 gear) yellow box connection is very good.
3. Engine stalled 3 times on a freeway run (drove about 30 miles on a freeway @60-90mph). It will crank but engine won't start right away. Key off for about 10 minutes, it will start and run.
4. It happened once on a freeway, I was accelerating from 4000rpm to about 6000rpm, suddenly engine hesitated and misfiring and stalled. After 10 minutes, I restarted, but engine speed was limited to 3000 rpm. So I shut it off, wait another 10 minutes, it runs ok.
I have a/f guage, it seems to run normal (always rich when boost is on).
Boost guage reads around 6psi to 9psi (over around 7000rpm)
Spark plug is NGK with heat range 8.
I am willing to go for tuning E-manage, but living in Grand Rapids, MI. Any good shop recommend near Chicago, or Detroit? Thank you.
