The Ultimate GReddy Turbo Kit Thread
Old Aug 26, 2009 | 06:39 PM
  #601
s800's Avatar
Any tuner recommendations are SE Wisconsin/NE Illinois? I went to King and had a tune, but they didn't seem real big on the e-manage.
Old Aug 27, 2009 | 05:46 AM
  #602
g352s2k's Avatar
Originally Posted by Revenge,Aug 25 2009, 08:07 AM
Mine kinda did the same thing but it really was not a big deal, I am now controlling the boost using the emanage ult boost by rpm. I am running 20psi with it and 1000cc injectors. And it seems to work, this may be a great fix for all the greddy guys getting boost creep. You may be able to run a much larger exhaust and TP (more hp) if you can find a emanage tuner capable of tuning like this. It does however take the tuner much more time.
hmmm would love to know more about this.
Old Aug 27, 2009 | 12:54 PM
  #603
jari8378's Avatar
Originally Posted by Revenge,Aug 25 2009, 12:05 PM
I think just a mac cable, Toan used the one from the AEM Tru boost I have. They are also going to install a switch so I can run two setting one at 20psi and the other just off the WG.
can you find out more information for us please.
Old Aug 27, 2009 | 01:09 PM
  #604
devs2k's Avatar
dscdd had a good link, maybe he can chime in
Old Aug 27, 2009 | 01:13 PM
  #605
jari8378's Avatar
^^ i posted something on the main thread that i believe EMU owners can appreciate.
Old Aug 28, 2009 | 04:56 PM
  #606
g352s2k's Avatar
Ok I was checking out under my hood and was missing 2 nuts to the manifold! Bought new ones tightened all of them and the exhaust def got louder you guys think I was leaking something? And if any of you are using an aem boost controller what duty cycle % are you at so I can get an idea, thanks!
Old Sep 2, 2009 | 11:37 AM
  #607
g352s2k's Avatar
NVM tightened to bolts did some data logs an have it at 30% duty cycle about 10psi pulling stronger then ever... right when i was gonna give up, it all works out.
Old Sep 2, 2009 | 05:53 PM
  #608
1fastminivan's Avatar
ok, so is it possible to "upgrade" the actual turbo without changing out the manifold?
Old Sep 2, 2009 | 07:42 PM
  #609
chad86's Avatar
Yah, a gt30 upgrade, Check this out
https://www.s2ki.com/forums/index.ph...ic=705184&st=0
I'm in the middle of doing this upgrade myself...
Old Sep 2, 2009 | 08:11 PM
  #610
itlynstalyn's Avatar
As am I! Make sure your actuator bracket fits before trying to put it on. Engineer X had issues with this and had to create his own bracket to make it work.
