The Ultimate GReddy Turbo Kit Thread
Old Sep 14, 2009 | 12:06 PM
  #631
JoeyBalls's Avatar
Originally Posted by sammy21c,Sep 13 2009, 07:09 PM
new problem came out. now car wouldn't start.
ECU is reseting by itself - everytime key on, clock is at 1:00
checked back up fuse 7.5A - it was blown.
At the last run, I remember clock was at 1:00 so I adjusted and drove about 20 miles. After 1 hour parking, it is not starting. Cranking OK. It is wierd.
Anybody have AP2 greddy turbo base map?
I really wouldnt drive it any longer. Take it to a tuner, something is wrong
Old Sep 14, 2009 | 12:23 PM
  #632
chad86's Avatar
Originally Posted by nsx_bob,Sep 14 2009, 12:25 AM
what if the cutout was right after the stock or aftermarket cat?
That may work... As long as the stock cat is in still... Or if you have the turbo out or not installed just port the WG... I run full 3" turbo back on my greddy tubo with no creep even when its cold out with a ported WG.... If you ported the WG you could ruin the cutout right before the cat
Old Sep 14, 2009 | 02:26 PM
  #633
SgtB's Avatar
This is NOT an EMU problem. Check and then re-check your harness for loose connections and most likely a pinched wire. It's a pain in the butt to shove all those wires back behind the cover, and damaging one is very easy. Also make sure your ground points under the dash are still tight.
Old Sep 14, 2009 | 06:26 PM
  #634
sammy21c's Avatar
Now the car seems to run fine. I made reservation for dyno tuning next Saturday.
1. The e-manage is still reading way higher speed (650km/h), should I just disconnect and jump the speed wires on e-manage?
2. I still need a AP2 base map. anyone please?
Old Sep 14, 2009 | 11:44 PM
  #635
mitcho168's Avatar
hi guys. to get it tuned do they tune the emanage or i have to get another ecu? thanks!
Old Sep 14, 2009 | 11:58 PM
  #636
boostftw's Avatar
The tuner will tune the emange thats connected to the stock ecu
Old Sep 15, 2009 | 12:31 AM
  #637
mitcho168's Avatar
thank you = ) hope to purchase the greddy kit within a month
Old Sep 15, 2009 | 03:18 PM
  #638
nsx_bob's Avatar
very nice thanks for the info.
Old Sep 15, 2009 | 05:01 PM
  #639
Revenge's Avatar
I have an ap1 map but not an ap2
Old Sep 15, 2009 | 07:30 PM
  #640
sammy21c's Avatar
Thx, I still have 12 days for dyno tuning. Anybody with AP2 base map, please?
