4.77 drag times?
i know i know, but i was wondering is anyone has ran there s2k stock, then with 4.77s all motor and the difference it had? just lookin to see what to expect. thanks
SURE AN s2k can be like any drag car..it just depends on how u set it up..also go check out the racing and competition forum coz its been talked about there many times...
anyway, heres mine..its not a 4.77 thou
mods first:
4.44FG, 2 way lsd, drive shaft shop aluminum light weight propeller, act flywheel and act HD PP with 6 pad disc, toda header, 70mm tp,70mm single cat back, modified airbox, some cooling mods..245/45 toyo ra1 tires on 16x8 on all four..and after about 200lb weight reduction...the lowest i got is 13.4 in a 1320 drag strip.... and 8.6 on an 1/8mile drag strip..and yea my car has a negative 3degrees camber on all four..so a little traction was lost (dont know if this has a big effect), but i lowered the rear tire pressure to about 15-17psi...this was done last year at Cali speedway and irwindale speedway...the time is got was ok considering the car was not setup for drag but mainly for turns,but it did ok imo...
right now i have the hondata toda reflash for my06, and some CF doors, and some CF lightweight bucket seats..so im expecting to hit 13 flat or a high 12sec....
il try to fing the time slips and post it....
mods first:
Originally Posted by qbmurderer13,Apr 30 2008, 12:24 PM
IMO the best gears for drag are the 4.44's. You dont have to shift to 5th, that one shift right at the end really kills you.
i really dont get why some s2k owners get the 4.77..its only good at start coz u feel the big grunt pull vs. other gear ratio..i never had a 4.77 but i drove a few with one, and honestly none of them had ever beat me yet, even if sometyms they get me at launch...
i say 4.44 is very good for ap2 and 4.56 is exellent on ap1's....but this is just me, and for my 2 s2ks i wont go any other way..and some other s2k owners with a higher FD ratio myt not agree with me coz there set up might complement their other choice of gear ratio(i.e. 4.77)...
also, i think drag slicks are some bfg drag radials on an s2k would be a killer too even without changing the final gears....
i am saving for some BF goodrich drag radials DOT street legal tires and another pair of rota 16x8 slipsstream for the rear so i can just easily swap them out when i go to the 1320 drags or 1/8 mile drags...
and hopefully this hondata reflash that i just got and my other weight reduction technique will help a lot....il be really glad to hit 13 flat or high 12's when i finish my setup for this coming summer.
yeah i think i wanted 4.77s cuz its more fun ya know? just seeing if it would help, i need Radials cuz with i/e i ran a 14.4 with a 2.19 60ft and that was the best, and i spun like crazy n 2nd and third
And if you spun 2nd and 3rd then you need some new tires or something, cause unless your boosted then theres no way you can spin all of 2nd or 3rd.
This has been gone over too many times now, people argue both ways here and they end up saying how the 4.77 only help at the start but this still isnt true though. Any gear has its powerband so you can be side by side and obviously have a 4.44 pull on the 4.77 if the 4.77 is right about at its shift point BUT the 4.77 should still pull on any gear, esp if the driver is just that, a driver that can handle his shifts well and very quick. Ofcourse the 4.77 will help in the 1/4 mile, but you have to be able to hit that last shift quick enough, if you granny shift, they will hurt you, if you can hit it on key, your in for about .5 second faster.
I think weve had 10 pages of this exact conversation
zeroptzero
Apr 1, 2011 04:59 PM
