Rebuild S2000 engine
Hi everyone,
I'm new to the S2000 world and just got an S2000 with 370,000 miles for a really good price, so now I'm going to build the motor. My budget is around $2500.
Any thoughts or pointers ... or can I even rebuild with $ 2500?
What would you guys do ? I'm in so cal
Banned
It'd be tough to do for $2500.. for that price your best bet is to buy a good lower mileage ap2 short block.
Factory parts are very expensive and I can tell you that you will have to go with oversize pistons. A motor with that many miles will have ovaled/egged cylinders.
https://www.s2ki.com/s2000/topic/104...-short-blocks/
to do a complete motor with new oil pump, timing chain, tensioner, refresh the head with a valve job, new guides, seals, new springs and retainers you're looking at around $3800-4000 or so.
I agree with Wadzii for I did the same you did bought a cheap s2k with a ton of miles. Im driving the car until winter then Ill tear her apart and do a build. for 2500 you might be able to get the head built though but not the whole motor.
But you might be able to resuse a lot of stuff but I would just get new rings, head gasket, timing chaine, head studs, cluch, throw out bearing, motor mounts, maybe bearing it just depends.
Big difference in cost to BUILD a motor vs just to rebuild it. Its not going to take $10K to rebuild, especially if you just replace things that need replacing, and aren't going for added performance.
But befroe you even go there, what is your compression on all 4 cylinders? Does it burn a lot of oil or knock? Are you sure you even need a rebuild? You might be able to get away with driving it as-is for many more miles before an engine issue forces a rebuild.
Once that does happen, with that many miles on the car itself, I would be thinking to drop in a good used motor (as already mentioned), rather than rebuild. Would be cheaper, and faster to complete.
370,000 miles damn! please post pics of this car and if you dont mind telling us... how much did you pay
Takethephil
01-28-2013 10:36 AM
