Canton pan thoughts here
Also, is the provided washer composite? I might pickup a few copper ones as I'll need them later anyway..
I hate allen bolts as well, but I guess they use them more often than not for clearance reasons.
Originally Posted by dsddcd' timestamp='1407653326' post='23280379
Well, I have run mine at several track days now with no issues. As Jason (yamahaSHO) mentioned earlier I am seeing less oil in the catch can now so I am assuming it is working but I don't have a pressure gauge so no hard data to offer.
As mentioned previously there are a few things I would change but overall I am very happy.
1.) Provide hardware with flanged head, I really hate using allen head bolts unless I absolutely have to.
2.) Use the OEM dowels to help line up the pan, or mention that they need to be removed
3.) Provide bolts and nuts for the bell housing cover plate.
4.) Use a better drain plug, I could not get mine to stop dripping and had to buy a new one from the auto parts store.
My mechanic hates allen heads as well. But couldn't give me a reason why. lol. Although he didn't have any English wrenches.
Using dowels is impractical as previously discussed, and, I could be wrong, but I'm pretty sure one of the two instruction sheets mentioned this.
I just used the existing bolts and put a nut on the end.
My drain plug was fine. Did you try a new washer before you bought an new bolt?
But, it make sense they strip easier because the more "surfaces" there are, the less force can be exerted on them until the wrench slips. Same for regular box end wrenches...if you don't want to strip a bolt, use a wrench with less "surfaces". I guess the ultimate would be a triangle, huh?
Originally Posted by suterusu' timestamp='1407807762' post='23282731
Late, but I thought I'd chime in. Installed on my '07, left off stock windage tray, flywheel cover doesn't fit with stock flywheel. I let Jeff know and he said they were working on a fix. Considering spacers in the interim.
Got around to finally installing the pan. I left off the stock baffle plate as making it fit would've been a big headache. I had to trim the Canton baffle plate like Rain H8R did. I just removed it, cut it, then reinstalled it. Also, the pan sits closer to the front crossmember than I'd like. I had to move the little bracket w/ the rubber stop and shifted it front as far as it'd go, to get a few mm clearance between the rubber and the pan. Initially I couldn't get the rubber stop back on. It's a little closer than I like but it should be ok, I'll keep an eye on it. The 1/2" npt bungs also would only allow the 1/2" fitting to thread a few turns, so I ran a tap through the threads so they'd get another couple turns. The holes for all the mounting bolts lined up fine, I didn't need to enlarge any holes. The a/c bracket wasn't difficult to install, just loosen the top 2 compressor mounting bolts and it'll stay in place. I had to be careful threading in the 3 mounting bolts for the a/c bracket onto the pan as they weren't quite perfectly aligned, but I was able to get them on fine.
Also, the flywheel cover fit fine, but I'm running an aftermarket flywheel. I stuck a washer between the cover and bell housing to space it out a tiny bit just for piece of mind. I can't comment about leaking as it's just been installed. 6.5 qts it took to fill up.
Some other tips: Brake cleaner is your friend. Make sure the mating surfaces are very clean and free of oil/crud. This allows the rtv to bond to the metal surfaces and helps it seal. One of the rear corners where the oil keeps draining can be a bit of a pain, but if you work quick in between drips you should be able to get the pan on w/o much oil hitting the rtv at that spot. Be liberal w/ the RTV to make sure it seals well.
Edit: Link to RainH8R's post and picture of where to trim: https://www.s2ki.com/s2000/topic/101...t__p__23173299
In case the pictures get removed it's basically a 1/4" off the open edges closest to the timing chain.
[attachment=64815
an1.jpg]
[attachment=64816
an2.jpg]
[attachment=64817
an3.jpg]
[attachment=64815
an1.jpg][attachment=64816
an2.jpg][attachment=64817
an3.jpg]
