Canton pan thoughts here
Old Jan 5, 2015 | 07:20 AM
  #191
s2000ellier's Avatar
anyone have thoughts about not running the windage tray when install the canton pan?
Old Jan 5, 2015 | 07:28 AM
  #192
hondalovr13's Avatar
i didnt go off track once this season. imo the weld failed. it broke in the middle of the weld there is still some metal on the pan and on the mounting tab as well. also i took out the stock windage tray completely so the doesn't interfere with the plate at all either.
i wish i would have taken some better pics, but all i have is a low quality phone video that im not sure how to get on to this forum at the moment.
Old Jan 5, 2015 | 07:34 AM
  #193
davidc1's Avatar
Lot's of us did that. Doesn't seem to be an issue because the anti slosh plate essentially accomplishes the same thing. The distance between the ant slosh plate and the OEM windage tray is very small, so the both keep oil from splashing up. The clearances between the windage tray, pickup head, and anti slosh plate are apparently very, very small. My guess is on the order of a couple of millimeters at some points, so, sometimes it was just easier to remove it than to try to trim it to clear completely. I suppose if a machine was making the parts, and we had a few engines to measure the variances with, everything would clear perfect. But, unfortunately that's not the case.
(people....not making excuses for anything...please don't jump on that last couple of sentences...ok?)
Old Jan 5, 2015 | 07:37 AM
  #194
yamahaSHO's Avatar
Originally Posted by davidc1
Originally Posted by yamahaSHO' timestamp='1420474762' post='23456660
"Tray" is still not improper.
Press on...
Didn't say it was....now I'll press on.....
You didn't physically type that, but if it wasn't what was meant, there was zero point in even pointing it out.
Old Jan 5, 2015 | 07:38 AM
  #195
i was mostly concerned when heavy braking and the oil pooling in the front of the pan
Old Jan 5, 2015 | 08:06 AM
  #196
davidc1's Avatar
I don't think there is really an issue here. The OEM windage tray (which Honda calls a baffle) is only to prevent oil from splashing up to the crank. It doesn't really have anything to do with oil starvation under braking or anything else.
The stock pan, and the Canton pan both have a small plate forward of the pickup head to help keep oil around the pickup head during braking. I'm not an engineer, but I do believe there is enough volume of oil in the pan, and a small enough area in front of the pickup head towards the forward wall of the pan to keep enough oil pooled around the pickup head for any amount of heavy braking that you may do.
Old Jan 5, 2015 | 08:12 AM
  #197
yamahaSHO's Avatar
Originally Posted by yamahaSHO' timestamp='1420475871' post='23456693
[quote name='davidc1' timestamp='1420475307' post='23456676']
[quote name='yamahaSHO' timestamp='1420474762' post='23456660']
Press on...
[/quote]
Ahh...man. I thought we were pressing on? Ok..well, my only point of this post was to have the last word. Good day.
[/quote]
I did already state that you were annoying...
Old Jan 5, 2015 | 09:18 AM
  #198
my concerns were more about without the stock windage tray would there be a possibility of oil splashing the crank under heavy braking since the stock windage tray basically wraps the oil pickup but the canton pan does not have anything above the pick up
Old Jan 5, 2015 | 09:34 AM
  #199
SlowTeg's Avatar
Who gives a f*ck what it's called?
Back on topic.. yamahasho clearly has a valid concern and I'd be pissed if my welds crapped out on me and it caused problems.. It seems canton has some QC issues. I'm not sure why you need constantly run to their defense dave just because you lobbied to have the product created..
Old Jan 5, 2015 | 09:56 AM
  #200
gearhead1186's Avatar
Originally Posted by hondalovr13
so i am the one who had the weld break. i can try and post the video up later ( or yamahasho can post it).
i had the pan on all season, it had a small leak that was getting progressively worse, so i removed it to re seal it. i put a straight edge on it and found where it was leaking to be a low spot. i hit it with a hammer to get it close to where it should be.
as far as the broken weld. on the back of the pan there is a welded tab that holds the slosh plate. the plate is bolted to this tab and the welds broke right in half. it is still bolted to the baffel area but now the plate is loose on the back side. luckily it was a clean break, what if it wasnt and i had a piece go into the pickup. i could have lost a motor from the part i installed to fix that very same issue.
I discovered a pinhole leak on my pan as well right on the bead. It took me a while to find the source during the race season but since my car is stored on a lift during the winter I was able to narrow it down pretty easily. It wasnt worth me dropping the pan and rewelding it since I had issues getting it to seal correctly so I ended up slapping some JBweld on it. I can snag some pictures at some point if anybody is interested.
