Prepping for BSP
Old Sep 10, 2012 | 01:46 PM
  #111
Spaf's Avatar
Originally Posted by Mrsideways
Originally Posted by Spaf' timestamp='1347296182' post='22001123
Surge Tanks. Not legal
Time to start writing letters, Surge tank = a lot more economical then fuel cell. But knowing the SCCA they'll allow fuel cells but require them be made out of solid 24k gold only.
Agreed but I think they're being conservative because of safety or maybe perceived street-ability? I.e. maybe they don't want tanks of gas with loose AN fittings sitting in the trunk of a street driven car?
There's also a history of protests, etc with surge tanks, "cool cans" and fuel filters. Even if surge tanks were legal (I think this is a stretch, especially since some cars are running fuel cells in SP already and consider it a takeback), fuel cell clarification would still be good.
Ian!!! 996 GT3!!!
Old Sep 10, 2012 | 01:55 PM
  #112
josh7owens's Avatar
Anyone created a full list of every mod allowed in BSP or is that part of the witch craft, you gotta figure it out on your own and interpret the rules your own way. Is there much gray area in the rule book? A protest would suck.
Old Sep 10, 2012 | 01:59 PM
  #113
steguis's Avatar
I found a few online but think STR car with unrestricted wheel/tire, all the fender modding you want (short of replacing it) and use any part from any year S2000 + Any flywheel and clutch, full standalone ECU, any steering wheel, any radiator. That's pretty much all that's relevant.
Old Sep 10, 2012 | 02:09 PM
  #114
Spaf's Avatar
Radiators aren't free. Not much to be gained there unless you want better cooling for the track...
L. Engine cooling radiators may be replaced with alternate parts subject to the following restrictions:
1. Radiator core dimensions (width, height, thickness) must be no smaller than the standard part.
2. Radiator must mount to OE radiator mounts.
3. Fluid capacity and dry weight of the radiator must be no less than that of the standard part. Installation of an alternate radiator may serve no other purpose (e.g. to allow a cold air intake passage).
Old Sep 10, 2012 | 02:16 PM
  #115
steguis's Avatar
Ah yes I forgot about that. I actually have a larger radiator in mine for track use which is why I was happy to see I could at least upgrade the radiator within the rules.
Old Sep 10, 2012 | 02:31 PM
  #116
steguis's Avatar
For an AP2 swap, can I move my head to a new ap2 block or do I need to source a complete f22c?
Old Sep 10, 2012 | 02:47 PM
  #117
mLeach's Avatar
If they have the same stamping/part number, you can use it. however, it will need to be all AP2 components otherwise. cams. springs. valves/keepers/etc. you're better off sourcing an entire f22c.
Old Sep 10, 2012 | 03:40 PM
  #118
CKit's Avatar
Originally Posted by Rodney
Originally Posted by steguis' timestamp='1347287463' post='22000717
Anyone consider running Goodyears over Hoosiers?
well, after goodyear won AS, they got my attention. they seem to be better handling heat issues over hoo hoos, but i have not driven a set yet.
I tried Goodyears last year and they had soft sidewalls and chunked early. They lasted half as long as comparable Hoosiers. Maybe I just got a spotty first run set, but was NOT impressed.
Old Sep 10, 2012 | 03:47 PM
  #119
CKit's Avatar
Uyeda, congrats on the BSP jacket! The car looked dialed in.
Old Sep 10, 2012 | 03:52 PM
  #120
03threefiftyz's Avatar
Jason had a blown shock and still beat us. That said, we as a group (BSP), need to pick up the pace. We were way off the pace compared to DSP. I'd expect that gap to close considerable next year (or at least I hope).
